Five Lug GC Coilovers
  • Pussy30
    • Feb 2011
    • 463
    So guys, how do get I get lower. I know this sounds terrible but ive gotten a quote on just raceland fronts, would they be able to get lower?
    • 2002maniac
      • 4260
      Are you running camber plates? They will give you a bit more travel.
      • Pussy30
        • Feb 2011
        • 463
        Yes the IE3 camber plates
        • Pussy30
          • Feb 2011
          • 463
          bump
          • etxxz
            • Feb 2006
            • 2085
            dude, u asked my by pm and i told you everything you needed to do.. stop being a waffleswaffleswaffleswaffleswaffles30 and cut those struts
            No more e30s for me.
            88 black BMW OBDII 332is dedicated track [sold]
            88 BMW OBDII bronzit 332is [RIP 03/08]
            91 BMW 325i [sold]
            86 Corolla 'Ae86' HB 20v trd [sold]
            http://youtube.com/watch?v=pTj7Hn9v5Rs
            • Pussy30
              • Feb 2011
              • 463
              Ughhhh i dont trust myself enough to hack up a strut that much.
              But thanks so much for the help, I wish the pics from your thread stilll worked.
              • Pussy30
                • Feb 2011
                • 463
                Anyone know if any other e36 full coilover assemblys go lower?
                • Pussy30
                  • Feb 2011
                  • 463
                  up
                    • 34839
                    how does the stack height of IE camber plates measure up to GC or vorshlag?
                    what about using shorter springs?
                    cutting/welding the perch lower?
                    there's lots of options..
                    • Pussy30
                      • Feb 2011
                      • 463
                      The ie plate is about 1/4 of a inch thick and goes above the stock bearing carrier. Im almost positive the shock is bottomed out and THATS my issue. Also Im unsure weather completly grinding off the perch and rewelding a bead is safe to do in this sort of strut.
                      Thanks for the reply though.
                        • 34839
                        so you've added 1/4" to the stack height. you've gone backwards.
                        get some real camber plates - vorshlag, GC, whatever - that will give you at least a half inch more travel, probably a lot more.
                        • Pussy30
                          • Feb 2011
                          • 463
                          Do they eliminate the need for the stock bearing carrier?
                            • 34839
                            yes, that is where you gain suspension travel.
                            • bimmerteck
                              • 762
                              Yes, the StanceWorks zero clearance coilovers built by AST for the e36 chassis will go significantly lower b/c they have a shorter strut designed to be run low unlike the bilsteins.
                              Do not take this as a sales pitch, but you asked so I answered. I would personally cut the housings and shorten them myself.
                              • Pussy30
                                • Feb 2011
                                • 463
                                I hear the cosmo camber plates get pretty good reviews, any thoughts on them?
