Help me pick spring rates R3V!
  • Wishno87
    • 6025
    Alright guys the car is my DD but I would also like to do some autoX and track days when the car is finished. I have IE3s right now which don't bother me at all and I would be comfortable with going considerably stiffer. Here is where it gets tough though. I carry rear seat passengers often and also pull around a small single axle trailer a couple of times a month. This would mean I would need to get stiffer than average rear springs no? How would that affect handling? Thanks for any help. You guys are the best
    Cliffs: DD/Track setup. Often times carry a lot of wright in the arse.
  • CorvallisBMW
    Long Schlong Longhammer
    • 13039
    I'd say something along the lines of 475/600
      • 34844
      I think you'll get a million opinions on this. But for a RWD car I'd give the rear a bit more bias than 475/600, remember the effective rear spring rate is about 1/2x the front.
      • nrubenstein
        • 3148
        You don't need to run high rates in the back. You just need to run higher. Given where you are, I'd suggest 550/750ish if you're running real shocks. And if you aren't *at least* running something at the GC Koni level, you need to be.
        2002 BMW M3 Alpinweiß/Black
        1999 323i GTS2 Alpinweiß
        1995 M3 Dakargelb/Black
        - S50B32/S6S420G/3.91
        1990 325is Brilliantrot/Tan
        1989 M3 Alpinweiß/Black
          Unless you go to coil overs the only stiffer OE sized springs that I know of would be Turner J-Stock springs (680/1026). That's almost double the spring rate of the IE S3's (315/570) and is going to be awfully stiff on a DD.
          • KennyT
            • 542
            Just remember stiffer is not always better.
              • 34844
              not always, but it often is. :)
              • Wishno87
                • 6025
                I guess I should have clarified I'm getting coils. Going from progressive rates to linear would also make a difference huh?
                • reelizmpro
                  • 9558
                  absolutely. I switched from 477/650 on my vert to H&R Races (progressive 310/580) and it's more comfortable on the street and rides great. It's a good compromise between street/track. The M3 will be getting the 477/650 GC's.
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • Wishno87
                    • 6025
                    I'm going to be using billstien sports for now but does 500/700 sound like a good compromise then?
                    • UDelaware30
                      • Dec 2009
                      • 336
                      450-650 on mine. perfect with the m20, may pop it up to 550 in the front now with the m52.
                      • Wishno87
                        • 6025
                        Ya I already have an M50 in mine but plan to install AC as well in about 2 months. Anyone else DD a car in the 500/700 range?
                        • CorvallisBMW
                          • 13039
                          How soon are you looking to order them? I'm hoping to have my 475/600 on in 2-3 weeks, you can test it out.
                          • 2002maniac
                            • 4260
                            Yeah, that's about as high as you'll want to go without revalving the shocks. IMO bilstein sports don't have enough rebound damping to handle super stiff setups.
                            • Wishno87
                              • 6025
                              500/700 purchased. Thanks guys!
