my suspension
  • zandi
    • Apr 2004
    • 602
    my suspension
    So far, I have:
    New Control Arms, plus new stock bushings
    New Tie rods
    H&R Sport springs, Bilstein Sports
    Ground control RSM's
    Falken Azeni's Sports just installed
    The handling still isn't satisfactory to my liking, the steering wheel still feels really loose and the ride isn't so smooth but I'm thinking thats normal because of the H&Rs.
  • nickmp0wer
    • 1427
    ok, search for e36 steering rack on this board
    • Mystikal
      Wheel Fitment Expert
      • 9602
      It rides stiff because of the Bilsteins. They have high compression valving.
      • zandi
        • Apr 2004
        • 602
        What about strut bearings, could they possibly be very worn causing this loose steering?
        • Jon325i
          • 6934
          Not likely. Seeing you replaced the control arms and tie rods, my next guess would be to look at the steering rack. When you did the work on your car, did you examine said steering rack? What is the overall condition of the dust boots at the ends? Any signs of leaking fluid? BMW steering racks use ATF (Dexrol 3 or 4) for power steering fluid so if you see any of this stuff coating the outside of the steering rack or on your driveway, you may be due for a replacement. Should the worst case scenario apply, contact http://www.meridianautoparts.com/. They offer quality rebuilds and are great to work with. Experience talking here :D
          Jon
          Rides...
          1991 325i - sold :(
          2004 2WD Frontier King Cab
          RIP #17 Jules Bianchi
          • zandi
            • Apr 2004
            • 602
            My steering rack doesn't leak anything, changed my tie rods and didn't notice any leaks
            • zandi
              • Apr 2004
              • 602
              So then would it have to be the strut bearings or is that just how the steering rack for e30s are?
              • kencopperwheat
                King of Kegstands
                • 14396
                I'm guessing that some of the 'loose' feeling has to do with the stock control arm bushings. Try some Treehouse Racing CABs... they'll increase the caster.
                You might also try to increase the negative camber on the front wheels.
                Originally posted by Gruelius
                • nickmp0wer
                  • 1427
                  search about e36 or z3 steering racks on this forum like i said, then get the right parts and put one in your car
                  • zandi
                    • Apr 2004
                    • 602
                    The alignment guy said that since my car has negative camber he put in toe in to compensate for it, so I tell him to put some toe out? I might go for treehouse, they sound really good but these bushings I have on now are new.
                    • zandi
                      • Apr 2004
                      • 602
                      Also, bumps seems to affect the steering a lot, is this also maybe because of toe in?
                        • 34835
                        you don't want extra toe in regardless, and I'm having a hard time seeing how that compensates for negative camber (which is kind of the point in lowering your car).
                        • zandi
                          • Apr 2004
                          • 602
                          Alignment guy told me that the negative camber I got by putting in my H&Rs will eat up my tires fast so he put some toe in to compensate for that and make the eating away much slower.
                          When I put my H&Rs and bilsteins in I didn't regrease the strut mounst and I wasn't careful with them, so I'm thinking maybe I screwed them up. But, it could be actually that I have too much toe in huh?
                            • 34835
                            that's nonsense.. you will still have negative camber (with just H&R sports it's doubtful that it will eat your tires up "fast") but you will also have shitty handling. so now you have the same increased tire wear as before but without the performance benefits.
                            • Mystikal
                              • 9602
                              Camber doesn't eat tires. Toe and waffleswaffleswaffleswaffleswaffles driving does. ;)
