Help: toe adjustment on lower cars
  • Sputnik
    • Jan 2010
    • 808
    I just lowered my car on bilstein sport ands h&r sports and I have stock 14" basket weaves, what should be the ideal toe (and/or camber if it applies) or is factory spec just fine?
    Thanks, I'm getting it aligned tomorrow...
  • Sagaris
    • Sep 2009
    • 2243
    Factory spec. I must have had some serious toe-in on my car because I just had mine re-aligned and my car no longer feels like I have a bad power steering pump. I never would have thought that incorrect toe would add so much steering effort. Just thought I would add that.
    • phreshkid
      • 4655
      Bad toe is much worse than improper camber. Once I got an alignment, everything felt so awesome.
      • Sputnik
        • Jan 2010
        • 808
        Yeah, I just hate driving on the highway when my car's tires like a club footed baby
          On a lowered car you will reduce the rate of tire wear that results from the increase in camber by using less toe-in that the stock spec calls for. Zero toe will yield the best tire life, but that demads that you drive the car 100% of the time. A compromise is to set to for no more than 1/16" total toe.
          • Sputnik
            • Jan 2010
            • 808
            Not to sound like an idiot, but what do you mean I have to drive the car 100%
            Thanks for the info though...
            • george graves
              • 19997
              He means you can never stop driving - not even for gas. I suggest starting at a high elevation.
              Originally posted by Matt-B
              • Sagaris
                • Sep 2009
                • 2243
                oh gosh, I have a family though, I dont think im ready for true E30 ownership :puppy:
                • Quadrajet
                  • Jul 2008
                  • 1278
                  I think jlevie means that the car will be less likely to self-center and will need constant input to drive in a straight line.
                    Correct! With zero toe there are no self centering forces tending to keep the car traveling in a straight line. You have to pay attention and drive the car all the time or it will wander.
