coilovers
  • ak-
    • 12422
    #31
    Originally posted by frickendom
    Just curious, does cosmoracing coilovers require welding?
    Garbage
    Originally posted by illest318i
    What about D2 coilovers? I'm getting those for mine...
    And, garbage.
    1991 325iS turbo
    • Dj Buttchug
      • Jun 2010
      • 7673
      #32
      Originally posted by ak-
      Garbage
      And, garbage.
      for the money there actually half way decent...
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • frickendom
        • 382
        #33
        Originally posted by Dj Buttchug
        they dont require it but if you dont you might not be able to go as low as you want
        so cosmo doesnt either, correct?
        • Dj Buttchug
          • Jun 2010
          • 7673
          #34
          not sure about those. if the setup is similar to that of d2 then no welding is required.
          my coils are k sport. i didnt weld anything but i cant really lower my car in the front anymore until I fab them
          Ig:ryno_pzk
          • XvillainousX
            • 176
            #35
            Originally posted by kalib0y
            Yes they are a great buy if one has enough courage to try the "newer/younger" company out. I did, I love em, and they do what I need them to do on the track and on the street
            I would definitely like to see someone order one with the sway bar tab relocated. I highly doubt the offer that option.
            Cosmo coilover are basically coil spring and sleve. You could get away without cutting the factory perch but then you couldn't really lower your car. Its best to remove the factory perch. If you plan to go this route just to go to Colman racing and order race quality perch for 45-65 bucks and order spring separately.
            Yes they do require welding.. Do note this is a shop sponsored car. Check out the wack ass install...
            • ak-
              • 12422
              #36
              http://www.r3vlimited.com/board/showthread.php?t=165838
              What do you mean a whack ass install? That's how it's done.
              1991 325iS turbo
              • jaywood
                • Jul 2010
                • 4528
                #37
                • kalib0y
                  • Dec 2004
                  • 3620
                  #38
                  They sent me the tab to weld on and the sway bar links and I got them for free ;)
                  95 7.1L 16V E36 M3
                  Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
                  LIKE my Facebook Page! CLICK HERE
                  • XvillainousX
                    • 176
                    #39
                    Originally posted by jaywood
                    Literally its a hack job..
                    No welding helmet or gloves? What is that tinted glass?
                    • jaywood
                      • Jul 2010
                      • 4528
                      #40
                      :wgaf:
                      That doesn't make it a hack job
                      • Brandon12V
                        • 1318
                        #41
                        Actually, that glass looks to be about the size out of a standard welding helmet. Just bc he's not wearing a welding helmet or gloves doesn't mean he's doing a hack job. My buddy graduated with honors and top of his class at Hobart College, worked 3 years doing fabrication for C&R Racing, and is now an entrepreneur doing his own metal artwork and freelance jobs. He's quite successful, does a great job, uses the SAME external welding glass method. granted, he does wears gloves and a jacket bc he doesn't like UV burns or arc pops sticking to him.
                        Originally posted by Ryan...
                        It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
