length of rear coilover spring?
  • chop_suey
    • Nov 2009
    • 270
    On an early, high rear arch car, what length should the coilover springs be in the rear so theres minimal wheel gap? Are adjusters needed?
    I was thinkin maybe a 5" or 6" 700ish lb spring.
    85 325e 5spd
  • E30SPDFRK
    • 5690
    If you want no gap with that rate, either a 5" with no adjuster or a 4" with one.
    Byron
    Leichtbau
    • Jafxod
      • May 2011
      • 1301
      Im running 6" GC 550lbs springs and im tucking a little bit with 205-50-15's. Hope that helps.
      • kalib0y
        • Dec 2004
        • 3620
        i run a 6in spring w/o adjuster and all i do is play with my spring pads
        95 7.1L 16V E36 M3
        Motorsport Hardware ***Wheel studs and Spacers!!!--->FOR SALE 4/5 Lug Stud Conversion Kits available CLICK HERE
        LIKE my Facebook Page! CLICK HERE
        • E30SPDFRK
          • 5690
          You have a late model
          And you most likely do as well.
          This is JPlue's car, 5" 700lb rear spring with no adjuster.
          Byron
          Leichtbau
          • DJ W
            • Apr 2011
            • 185
            where would one find a 5in 700lb spring im getting frusterated with searching i only find 8 and up or 150lb 5in
            thanks
            • kalib0y
              • Dec 2004
              • 3620
              GC, TCKline, or BC
              95 7.1L 16V E36 M3
              • Jafxod
                • May 2011
                • 1301
                Yup, Im late model.
                • bimmerteck
                  • 762
                  thanks
                  I would start with the eibach ERS catalog.
                  Eibach engineers, manufactures, and sells the highest quality performance aftermarket suspension products in the world.
                  • chop_suey
                    • Nov 2009
                    • 270
                    --thanks for the pic e30spdfrk, that helps alot.
                    ^^^arite cool deal, ill look there aswell.
                    BTW what, if anything, holds that spring in place when the car is raised?
                    85 325e 5spd
                    • DJ W
                      • Apr 2011
                      • 185
                      nothing does the last ones i had i would half to check them when i set it down they just sit around the little perches
                      • DJ W
                        • Apr 2011
                        • 185
                        ordered 2id 5in 700lb H&R along with a short shifter
                        • chop_suey
                          • Nov 2009
                          • 270
                          lemme know how that 2" ID spring fits, and pics too if u can
                          85 325e 5spd
                          • DJ W
                            • Apr 2011
                            • 185
                            i will they should be here this week they wer on back order?
                            • DJ W
                              • Apr 2011
                              • 185
                              5in 700lbs rear springs there not low enough for me.
