Springs that will slam my car
  • Suspence
    • Jul 2009
    • 943
    Instead of doing coil overs... what springs/shocks can I run out there that will slam my car and give a raked stance? I have cut IE springs, Biggest mistake of my life.
    Any help is appreciated. thanks!
    -Spencer
  • ak-
    • 12422
    Assuming you're on/hitting bumpstops. That's as low as it's going to get.
    Eibach pro-kit and 60/60 kits seem to be the lowest I guess though.
    1991 325iS turbo
    • LJ851
      • 7919
      Do you want your car to ride like shit? One reason people with slammed cars have coilovers is to get really hard springs so the car doesn't bounce off the bump stops all day long. If you want slammage , you need stiff springs and shocks so the suspension doesn't move much.
      Lorin
      The M30 is God's engine.
      • Ant_e30
        • 292
        ^ you also need the shortened shock bodies to allow travel not just hard springs
        • Wishno87
          • 6025
          +1
          I went from IE3s to GCs as well.
          • wille28
            • 113
            try FK 75/50 look like very low for only spring maybe FK 75/50+e90 drop hats=very low
            • Lof8
              • Oct 2006
              • 2827
              Just curious, why do you hate the cut IE3s? I've been running them on the street/track/autox with great success everywhere for about 3 years. Is it not low enough for ya? What shocks/struts are you using?
              I have never once hit the bumpstops.
              S50'd
              Originally posted by TDE30
              What is this faggy shit I have happened upon?
              I can always live in a M3. Can't M3 a house.
              • e30nub
                • Jun 2008
                • 1741
                My sig shows FK 60/40 w/Bilstein sports. Rides pretty good, but I have absolutely nothing to compare it to.
                -Pierre
                1987 535is
                1988 325is
                • Suspence
                  • Jul 2009
                  • 943
                  They just make crazy noises, I dunno why?
                  I want lower, they are Bilstien shocks.
                  • ak-
                    • 12422
                    He probably cut more than you
                    1991 325iS turbo
                    • Lof8
                      • Oct 2006
                      • 2827
                      I've cut 1/2 coil from the top and 1/2 coil from the bottom. I have no odd noises and have never bottomed out. I don't know how much you've cut already, but I'd try cutting more. I'm not aware of any stock sized lowering springs that offer a higher spring rate. good luck with whatever route you choose.
                      S50'd
                      • Brandon12V
                        • 1318
                        If you already have bilstein sports, just slap on the GC coil kit. its only 400 bucks and you can choose your spring rates.... most spring kits come close to that price anyway.
                        Originally posted by Ryan...
                        It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                        • IRON-E
                          • 16548
                          Coilovers > all other suspension set ups
                          @IRON-E30 aka Edwin:D
                          • ak-
                            • 12422
                            lmao what?
                            And if my math is correct, lol, it means you pretty much cut 1 coil which is what everyone has done without any sacrifice. I even think Janderson has 1 coil cut on his E30.
                            1991 325iS turbo
                            • Stephen
                              Шлем ишака
                              • 10774
                              you can cut more. but i would cut your bumpstops as well, otherwise you'll be close to your bumpstops
                              edit: i would get coilover sleeves. There's not much reason to stay with stock size springs if youre looking to get low. And if you want slammed, you're going to need to go farther than that
