The Official Coilover/Springs/Shocks Thread
    I just sent off some spindles and measurements to Holland. Should have something nice for this thread in about two weeks...
    -Alex
      Good thread write up bro
        Originally posted by howdyhoayman View Post
        would it be safe to ask on this thread what people think about their set of JOMS coilovers?
        Originally posted by M-technik-3 View Post
        Be safer to ask the guys who have had them on their car the longest. I'd rather not comment on a product I know squat about.
        The H&R's that I own...top notch quality. Then again if you can find a set these days and at under 2K for them is rare.
        I love my H&R's coilovers, well worth the price, 10+ years and still going strong., but,
        would love to get my hands on a set of front JOM adjusters for my e30 m3 5 lug swap., with them there's no need to cut and weld anymore.
        not too bad for 10 years http://www.bimmerfest.com/forums/album.php?albumid=7028
        springs to choose from ... http://www.bimmerfest.com/forums/album.php?albumid=7029
        and camber caster plates, etc... http://www.bimmerfest.com/forums/album.php?albumid=7557
        Check out the AFCO bearings on GC's adjusters, they help reduce coil's binding during slow turning, etc., very good upgrade and comes in various diameters
          Originally posted by fporro View Post
          I love my H&R's coilovers, well worth the price, 10+ years and still going strong., but, I would love to get my hands on a set of front JOM adjusters for my e30 m3 5 lug swap., with them there's no need to cut a weld anymore.
          OT but I should have PM'd you over the weekend. I spent 5 days out on Oahu in Honolulu. The Outrigger Reef was nice as always.
            this one needs to be stickied, the other one is all just pics
            Originally posted by u3b3rg33k
            If you ever sell that car, tell me first. I want to be the first to not be able to afford it.
              Hey R3v members I need some help dialing in my coilovers. I purchased and installed Megan coils (essentially BC'S) on my 88 325 and seem to be having extreme wear on the inside edge of my rear tires. I've done some reading and this seems to be a common occurrence on lowered e30's but for instance in the images above, these cars don't seem to have nearly as much of a cambered rear end. I would like to increase contact patch on my tires. Any suggestions? Fyi- Havn't had the extra cash for a proper alignment, although it tracks straight.
                too much negative camber from a lowered car bro. Sucks donkeys. Need camber adjusters.
                There's a guy here that sells "adjustable subframes" that have the camber/toe plates welded in.
                On alignment, if you're gonna be tweaking your car invest in a Firestone lifetime alignment. Basically you're paying for a little under 2 alignments up front, but you can take it back any time you want for new alignment service.
                HOWTOs:
                DB vert plastic bumpers
                OEM Keys
                MTech1 docs
                88 ix Lach/Card
                91 ic Calypso 3.1
                86 Cosmo 2.7
                OEM+ or bust!
                  This thread doesn't get enough love.....
                    camber isn't as much of an issue as toe in is. A bit too much toe will wear tires out WAY faster than tons of camber. This is likely more his problem.
                    Either way, the fix is weld on adjuster plates. Make sure to get both toe and caber adjustment.
                      so i have an official direct from the mfg number to add:
                      cosmo coilover spring ID is 65mm (2.56")
                      so 2.5" springs ought to work just fine.
                        Bump for helpful thread
                          I want Performance suspension. Any recommendations?
                          Hey guys I drive an '87 325es m50 swap. The stock suspension is killing me and I'm sick of it. I want a whole new suspension set up but I also dont want to break the bank. I dont know where to start looking. If you guys have any ideas let me know.
                          P.S.
                          I dont want anything ultra lowerd. Nothing over a 1 inch drop from stock ride height.
                          Thanks,
                          Squadzilla
