Ground Control's service rocks!
  • FunfGan
    • Jan 2011
    • 4958
    Warning: I will be bitching. So a couple months ago I called GC, and got my coilover conversion kit. I told them I was running standard Bilsteins on a 318is and would be doing some track/ autocross and they suggested 400 front/ 700 rear. So, about a week after putting them on, my Bilsteins blew. After about a minuite of searching on here, I found thats a common occurance. Fast forward to yesterday, I call them up to order their valved koni's. Sounds simple enough, no? Well apparently b/c I have a 318is, I also need to purchase the 325is struts to be able to fit the Konis, and send in my current front springs/ adjusters to be swapped for Koni ones. total cost? around $1100 including shipping. Yet a full kit including adjusters, camber plates, struts, springs would only be 1450? If we gave Gc all that info originally, and they obviously know the Bilsteins don't last very long, why wouldn't they just tell me it was going to be 2x expensive in the end to not just by the whole kit? Ok. Im done.
    Edit: Thanks Trevor
    Go here be happy!
    Ratchet Garage e30 V8 build.
  • KenC
    King of Kegstands
    • 14396
    I've never heard of it being common.
    Originally posted by Gruelius
    • FunfGan
      • Jan 2011
      • 4958
      They're not valved for 400lbs/ 700lbs.
      Go here be happy!
        • 34839
        uhm, you don't need 325is struts for a 318is. the strut housings are the same. It sounds like they thought you had an early 318.
        • KenC
          King of Kegstands
          • 14396
          What do you mean by having to get 325is struts? 318is ones are the same diameter.
          • Lof8
            • Oct 2006
            • 2827
            Can someone explain how stiff spring rates cause a shock to "blow?" My understanding is the shocks dampen or resist the compression and rebound of the suspension. Higher rate springs will produce less suspension travel and less "work" for the shock.
            Sure, the valving may not be correct to match higher spring rates, but how do the higher rates cause the shock to "blow?"
            S50'd
            Originally posted by TDE30
            What is this faggy shit I have happened upon?
            I can always live in a M3. Can't M3 a house.
              • 34839
              they provide more work for the shock. the shock's job is to control the spring, not to absorb bumps. by increasing the rate the shock has to work a lot harder because the spring pushes against it more.
              • nrubenstein
                • 3148
                Basically, the greater force blows out the seals.
                2002 BMW M3 AlpinweiĂź/Black
                1999 323i GTS2 AlpinweiĂź
                1995 M3 Dakargelb/Black
                - S50B32/S6S420G/3.91
                1990 325is Brilliantrot/Tan
                1989 M3 AlpinweiĂź/Black
                • Brandon12V
                  • 1318
                  yep. too much rebound created by the spring can destroy upper seal on the shock.. At least when using a linear set. I don't know if this holds true on progressive rates.
                  Originally posted by Ryan...
                  It now emits a beautiful blue-ish yellow/green smoke from the exhaust?? No idea what would cause that color, but I assume its good.
                  • FunfGan
                    • Jan 2011
                    • 4958
                    Thats what I was confused about, I've never heard of the difference between engines having any affect on the strut size, but they said the m42 cars used a different strut...
                    Go here be happy!
                      • 34839
                      who did you talk to? whoever it was is dead wrong. probably wasn't Jay, but one of his minions?
                      • Fusion
                        • Nov 2009
                        • 3659
                        There were 45mm and 51mm diameter strut housings.
                        It's good practice to measure yours, since PO's could've swapped 'em and its not that hard to do to be 100% sure what you're ordering.
                          • 34839
                          45mm strut housings were only on *early* cars. the 318is was built in 1990-1991, there were only 51mm strut housings then.
                          • FunfGan
                            • Jan 2011
                            • 4958
                            I talked to Trevor I think? So I was correct in telling him that it wasn't different. Thanks for the help btw.
                            Go here be happy!
                            • z31maniac
                              • 17566
                              It sounds like a simple miscommunication, not a grand scheme to screw you out of money. That happens sometimes.
                              Next time, do your research before putting any cash down.
                              www.gutenparts.com
