H&R Race installed. Rear sits HIGH.
  • HowLowCanYaGo
    • May 2011
    • 21
    First post...did a lot of searching and lurking leading up to this point. Anyway, I have been redoing my E30s suspension. Installed Bilstein Sports paired with H&R Race springs and GC camber in the front. WOW, great drop, the tire is flush with the fender, nice and aggressive stance.
    However, the Bilstein Sports/H&R race in the rear did almost nothing to change the car's ride height. It still looks exactly the same as it did stock. What did I do wrong?
  • carguy101
    • Jul 2009
    • 495
    They will settle after a few weeks of driving
    • LJ851
      • 7919
      A pic would help.
      Lorin
      The M30 is God's engine.
      • reelizmpro
        • 9544
        Yeah you really have to drive it around a bit for it to fully settle. I have the same setup and it settled another 1/4" or so. It had a lot of reverse rake before but now it sits perfectly. I doubled up the pads in the back and removed them from the front. This is on a vert.
        88 M3 - LACHSSILBER
        89 M3 - ALPINEWEISS II
        • HowLowCanYaGo
          • May 2011
          • 21
          Thanks for the quick replies. I realize that it will settle a bit more but the car's rear cuurently appears to have no drop whatsoever. I have a pic but it doesn't show much. Ill take more if necessary.
          Here is the onlyv pic I have available:
          • d_elson0
            • Feb 2011
            • 242
            ^that picture is probably not as helpful as a full side shot :)
            • HowLowCanYaGo
              • May 2011
              • 21
              Springs might be upside down. I'll flip them around tonight. Updates after that!
              • Stoner Sam23
                • 186
                Something isnt right there that looks way too high. HR race is very low in the back. Gave me reverse rake
                • Philo
                  Ich esse kleine Kinder
                  • 3334
                  Early model arches probably contribute to some of your problem. You could always remove the spring pads. . .
                  -tim
                  Originally posted by Jordan
                  I like the stance
                  • blefevre
                    • Dec 2008
                    • 4287
                    That looks way wrong. Picture of the spring?
                    - E30, DSM, Golf R, Mazda 3 Skyactiv
                    • HowLowCanYaGo
                      • May 2011
                      • 21
                      Well, I did have the springs in upside down...so I flipped them around with high hopes, but my ride still sits at stock height. Heading to the car in a few minutes so I'll post pics. Any ideas are miracles.
                      What specifically do you mean by arches?
                      • delta159
                        • May 2011
                        • 7
                        Does anyone have a part number for H&R Race springs for a 88 E30? Thanks,
                        • Fusion
                          • Nov 2009
                          • 3659
                          I installed my fenders today and have the same problem except up front.
                          The car seems to sit like 1.5in higher even though the new top mounts should be about 3mm shorter and I put 3mm top spring pads instead of the 9mm ones.
                          Installed Konis and IE sway, same springs as before, new joints.
                          Will this "sit" or is something wrong? I set the sway bar links while the car was still in the air but I doubt they would lift the front.
                          I've only driven it about 2 miles.
                          Edit: maybe not that much (1.5in), now that I look at old pics.
                          • paresmi
                            • May 2011
                            • 31
                            I installed H&R race springs in my 86 eta literally last night and this is how it's sitting a day later and after a few hours of canyon driving.
                            E90 drop hats and all spring pads installed and it sits this low.
                            I do not have he shock and sway set up you do so I can not vouch for that affecting your height. But yea I'm curious to see what's causing your issue.
                            • Jaxx_
                              • Dec 2009
                              • 1880
                              theres no way that even with spring pads it would sit that high. you installed it wrong somehow. check for shit binding. you might have not seated it in the perch properly.
