H&R Race installed. Rear sits HIGH.
  • LJ851
    • 7919
    Your rubber trailing arm bushings are a integral part of your suspensions activity especially at low loads. Put your car on the flattest surface you can find and loosen all the trailing arm bushes, jostle the car around , and retighten them. This may fix your issue.
    Lorin
    The M30 is God's engine.
    • HowLowCanYaGo
      • May 2011
      • 21
      Well, it looks like Turner sent me the wrong springs. They are for the E46 chassis :-(
      • Galactodactyl
        • 182
        Definitely an annoyance, but I'm sure they will make it right.
        • Blackout
          • Apr 2011
          • 4130
          Didn't you check the part # or match it with the invoice/packing slip before installing?
          Anyway, its turner's fault. Were the open box?
          » PARTS FOR SALE
          » TRANSACTION FEEDBACK
          • JGood
            • Jan 2004
            • 7959
            Glad you got it figured out.
            Mental note: If you want to slam an e46, use e30 H&R Race springs...
            e30 restoration and V8 swap
            24 Hours of Lemons e30 build
            • FreedS4
              • 752
              Anyone notice that the driver's side rear sits a little lower than the passenger's side rear on Race springs? Just noticed it last weekend. Figured it was because I normally drive alone, so most of the weight is on the driver's side, but wanted to see if that was "normal". Thanks
              Chris
              • Stoner Sam23
                • 186
                Chris
                1 Check your tire pressure.
                2 Park on even surface
                3 diet plan fatty
                • FreedS4
                  • 752
                  3 diet plan fatty
                  Roger, wilco on all three!
