Power Steering Leak
  • lonestar22
    • Aug 2005
    • 417
    Power Steering Leak
    i have a pretty bad power steering leak in which i dont know where its coming from. of course it only leaks when i turn and a little after the car is turned off. i go through like one bottle a day. is this common in E30's?
    Originally posted by Lof8
    Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.
  • Jarvis
    • 2132
    E30 steering racks like to shit the bed every 100K miles or so. If you're losing a whole bottle of ATF fluid PER DAY, you probably need a new or rebuilt rack right now. You have the option to rebuild your current leaky rack, but I think you'd be better off just buying a known-to-be working one and swap it in.
    Wow. 1 bottle a day is bad... Have you looked under the car and made sure a line isn't just lose or broken?
    If you squeeze the rubber boots on the ends of the rack and fluid comes out (if the boot is ripped/torn) or you can feel fluid inside the boot, then the rack's seals are busted. Then it's definitely time for a new/rebuilt rack.
    • aschmidt
      • 457
      1 bottle a day!? Jesus christ man lol...if the seals are busted and you need a new rack and are looking from a bit of an improvement from the e30 steering racks, they have e30-e36 steering rack conversion kits at http://www.zionsvilleautosport.com/s...ct_Code=E30SRC. Just an idea. :D
      -Adam Schmidt-
      1988 Zinnoberrot 325iS ::dead::
      1988 Bronzit 325iS ::sold::
      1991 Alpine 318iS
      • lonestar22
        • Aug 2005
        • 417
        my power steering resovor has a sticker on the cap labeled ATF Only but my friends has a 86' and it has no sticker on it. did someone just randomly place a sticker there or what?
        • aschmidt
          • 457
          No it should have been there on yours. Unless otherwise noted you are supposed to use ATF. :D
          -Adam Schmidt-
          1991 Alpine 318iS
          • lonestar22
            • Aug 2005
            • 417
            the old owner was my gf's dad and he said thats where he would put it so u think i should be using ATF fluid is that part of the problem?
            • Digitalwave
              is a poseur
              • 6292
              What are you using? You should be using ATF just like the sticker says.
              RISING EDGE
              • george graves
                • 19996
                Do yourself a favor - before you get another rack hunt down Valveolean(spelling????) Max Life ATF fluid - it comes is a redish-brown plastic bottel.
                Stuff is amazing - also makes a non-leaking rack feel even better - more feedback, and smother.
                TRUST ME.....
                Originally posted by Matt-B
                • Jon '92 325ic
                  • 172
                  Leeking steering rack
                  Probably need to have your steering rack rebuilt. You can buy a kit from BMA Autoparts rather cheap and do it yourself, but I've read that it's a mother of a task. You can purchase a rebuilt steering rack (from someone like www.meridianautoparts.com) and have it installed.
                  In the short term, use Valvoline Stop Leak Transmission Fluid. After a few refills, the leaking should cease for a bit. This is just a band aid fix until you replace your steering rack though.
                    • 34839
                    TRUST ME.....
                    yes, I have the same stuff in my PS and tranny. it smoothed my trannys shifting and my rack is still tight and barely leaks a drop with 172,000 miles.
                    • A_325i
                      • Jun 2005
                      • 680
                      its valvoline err i work there and i see the name and hear it every god damn day working for valvoline sucks but i must admit there products are quite good and no im not just trying to get you to buy them because i hate this god aweful company :evil:
