Rebuilding steering rack
  • E30 Wagen
    • Jul 2005
    • 3434
    This is for a '89 325i. I had to pull the rack out because of a bad steering linkage. I don't like the looks of the rack that came out, like it's some cheap rebuilt unit or something. Anyway, I have two other OEM racks, but I have absolutely no idea of their condition. I see there are gasket sets like this one:
    http://www.pelicanparts.com/cgi-bin/...C%20Each%20%20
    Is it hard to rebuild a rack?
    My Feedback
  • DRTSRFR
    • May 2008
    • 1836
    It's not hard, but there are some tricky parts...
    This may help...
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • Blackangusinc
      • Jul 2010
      • 244
      This may help...
      http://home.comcast.net/~adamsjohn/3...eeringRack.htm
      The link doesn't work anymore. Anyone else?
      971-295-7077
      91' 318i
      • bastianshaw
        • Jan 2007
        • 2210
        just sell those and buy an e36 rack
        • LJ851
          • 7919
          Yes.
          One of most enjoyable mods i have done to my car.
          Lorin
          The M30 is God's engine.
          • Blackangusinc
            • Jul 2010
            • 244
            Does anyone have a link to an e36 rack rebuild thread?
            971-295-7077
            91' 318i
            • taiden
              • Oct 2009
              • 178
              Maybe I should do an e36 rack.. I should really replace my tie rods and boots, so I figured at that point I might as well go for the shorter ratio.
              • xxlbimmer
                • Dec 2010
                • 156
                Check the rack doctor:
                seems to be a good deal and comes with inner tie rod and boots plus 2 year warranty!
                Chris Leone
                chrisleonemotorsports.com
                rollcages and fabrication
                Remember cross threading is the only thing stronger than loctite!!
                • TobyB
                  • 5293
                  It's not particularly hard, if you're at the mechanical level that doesn't mind doing a head gasket.
                  The only real tricks are that there are some seals that are REALLY hard to get on and off
                  without damaging them (in the spool and on the piston) and that the spool runs directly on the housing-
                  eventually the housing will get grooved to the point where it won't seal very well.
                  My version was to disassemble the coupla racks I had, disable power steering in the
                  one that was the nastiest, and leave the other as spares.
                  Oh, btw, the later rack is (imho) easier to work on. But neither is hard.
                  t
