What are you guys with no power steering doing
  • nickmp0wer
    • 1427
    I want to get something that just screws into the rack and has a little nipple for a hose to attach to and run that hose to the little PS tank but i dont think i can find a part like that. any other ideas?
  • Digitalwave
    is a poseur
    • 6299
    If you don't want powersteering you should buy a euro non-ps rack.
    RISING EDGE
    • nickmp0wer
      • 1427
      but thats a longer ratio, and cost money. I'd like to upgrade to a m3 or z3 rack sometime, but not now
      • Digitalwave
        is a poseur
        • 6299
        What's the ratio? Pretty sure is that same 4.0 lock-to-lock.
        RISING EDGE
        • nickmp0wer
          • 1427
          i think it might be 4.5. Not much of a difference, but i'd still have to find one and buy it. Maybe i should just get some bolts that are the right size and plug it up with some ATF in there?
          • AndrewBird
            The Mad Scientist
            • 11898
            I think there are some poeple that do that and have had no problems. Try searching. There should be something around.
            • nickmp0wer
              • 1427
              what i just did was take the hose that goes from the tank to the pump and ran it from the tank to the rack so now there are 2 hoses going from the tank to the rack
              BTW should the steering colum that goes from inside the firewall to the u-jonts be able to move around a little? it also makes kind of poping noise when i move it round
              • Old'n'Slow
                • 436
                I've done it both ways and I'm here to tell you that running a power rack with "no power" isn't remotely close to how good real manual steering feels in these cars.
                First, the little guibo in the connector between the rack and the column is very soft in the power rack. It's very firm in the manual because it has to withstand a lot more torque. This offers a more direct connection and better feel. As a matter of fact, I'd have to say that my e30 with the euro manual rack that I got from my local dealer feels tighter and much better "on center" than the steering in my wife's Z3. Surprising since the e30 manual rack is a 21.45:1 ratio and the Z3 is 16.9:1!
                Second, you have such a heightened sense of exactly where the limits of the front tires are that you can really drive it at the edge without any nasty surprises.
                Steering effort is not really a big deal unless you are completely stopped and are trying to turn the wheel.
                It requires no maintenance and will never leak anything on my driveway. :D
                • Addissimo
                  • Mar 2004
                  • 1820
                  I did a z3 conversion and recommend it greatly. I'm not running anything through it, I just have both banjo fittings installed on the rack, with a tube running from one fitting to the other. Pretty simple, works well.
                  -Addis
                  Doing something M50 related? -> http://www.addissimo.com
                  On Myspace? ->http://groups.myspace.com/r3vlimited
                  BF2142 SN = BillyGoose
                  • Borat
                    • Jan 2005
                    • 494
                    I thought the manual rack was 4.1 lock to lock. Anyway, if thats the case the difference is so small its not worth worrying about. Steering effort aint too bad at all, if anything I think they are too light at speed.
                    • NC325iC
                      • Mar 2004
                      • 6565
                      is there any way to like make the steering wheel harder to turn but keep power steering, maybe with like a smaller pulley or less fluid flow or something? anyone know?
                      • nickmp0wer
                        • 1427
                        -Addis
                        so you have a z3 rack, and no power steering?
                        and my current rack for some reason leaks even though it was rebuilt like 10000 miles ago. I also has a lot of slop.
                        I would probably like to do a no PS e36 or z3 conversion, but maybe the manual rack could work
                        • Schnell 318
                          • 567
                          is the euro rack a straight swap rack for rack or is there more envolved?
                          • nickmp0wer
                            • 1427
                            i just faxed a form to a junk yard, and hopfully no one has bought it since monday.
                            I found a 80k mile z3 rack with a bent tierod for $100 shipped
