The bolt loose from the hub assembly. However the threaded part spins with the bolt. I can't grip the threaded part with anything. What can I do shot of cutting through it
Can not get the tie rod off. WTF!
Im having the same problem. the bolt wont move, up or down. Its pissing me off.
BUY MY WHEELS! BBS E50s!!
http://www.r3vlimited.com/board/showthread.php?t=275407
Originally posted by Lurker27Any man will tell you being blown is better than being stroked.
take a pickel fork to wedge between the rod and strut. that might work but you will chance tearing the boot. you could also cold chisel the nut off, you might damage the threads a bit, but re taping might fix it. cut the neck of the stud and be done with. Replace the tie rod.
put a jack under the tie rod to put some pressure on the tapered neck of the stud. then hit it with a air gun. GLsigpic
I've tried most of what you posted^^ Except for the cold chisel and cutting the stud
Put a floor jack under the bottom of the tie rod and use that to put pressure on the bottom. It should hold the ball joint in place so you can spin the nut.
EDIT: damn someone beat me to it
Originally posted by ROLLingKINGi have a bronzit and plan on making it look sweet.Originally posted by slammin.e28Moral of this story?
I ran into this on a few e30s... if the car is on jack stands, simply take the edge of the crown on your jack (I'm talking a real floorjack, as in fast-rise, low profile) and put it on the center of the balljoint, jack it up until the car is slightly lifted off of it's jack stand (jack stand remaining in place for safety) then turn the nut SLOWLY and DELIBERATELY.
One turn, half turn other direction.
This usually happens when some of the threads are collapsed, I had to shorten some of the tie-rod and control arm bolts because the ends were completely mangled.
Good luck.
