Ruff Camber Plate Rebuild?
  • andyhurz20
    • Sep 2009
    • 50
    Hi Everyone,
    I have a set of Ruff Camber Plates that after last years track days has developed play, and does not function correctly. I was wondering if anyone know where to purchase more bearings so that I can rebuild the camber plates? Also, there was a set of nuts that you could purchase in the past, that were machined to grab more threads down inside the bearing, I was wondering if anyone knew where I could pick up a couple of those too? Thank you in advance for the help.
    89' and 94' 325is
  • Teaguer
    • Sep 2004
    • 6167
    Maybe try here: http://www.ruff.tw/Contact.html
    Or better yet, throw your Taiwanese junk in the trash where they belong and buy something from a real company.
    • TobyB
      • 5297
      ...or search for 'spherical bearing' using the google on the internets...
      Even a high- quality spherical bearing won't last forever in that application.
      t
      • JGood
        • Jan 2004
        • 7959
        I have a set with maybe 1000 miles on them, with the newer updated nuts. I'd consider selling them to you, if you want to go that route.
        e30 restoration and V8 swap
        24 Hours of Lemons e30 build
        • andyhurz20
          • Sep 2009
          • 50
          Thank you for the offer. I think that I would eventually run into the same problem if I bought yours. I think that I'm going to have to invest in a good set since I am planning on doing a bunch of track days this year.
          89' and 94' 325is
