Are you 100% sure that the lock washer isn't holding it AT ALL? Bend back the bent over flaps with a chisel and hammer.
Tie Rod Lock Plate
So some play has developed in the rack, looks like I might need a new one :(
With as much force as I could get on that adjustable wrench with that pipe sleeved over it, it would not budge. I had soaked it in liquid wrench muiltiple times and beat on it with a hammer also.Comment
You're making it really hard for us to try and help you. Just take a picture of the joint where the inner tie rod meets the rack. A clear, well lighted picture. Not a vertigo-inducing YouTube video.Originally posted by Grueliusand i do not know what bugg brakes are.Comment
judging from the video you are tightening it instead of loosing.Comment
The rack may not need replacing. The clue would be how much play there is between the steering shaft and rack shaft, or if the rack was leaking.
There is no lock plate at all, thus it is probably held on with Locktite. Heat will be necessary to break down the thread sealant.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
