&%@#ing stuck.
  • stillkotd
    • May 2011
    • 127
    &%@#ing stuck.
    Sooo, I finally got all the pieces I need to ditch my 4x4 status, and started the job this afternoon.
    How the heck do you get the control arm and the tie rod off the bottom of the strut?!?! I have the Bentley Manual and did everything it says to do, and have checked and double checked to make sure there's no nuts or anything holding it on. The bolts that come up from the balljoints seem to be permanently attached to the lower part of the strut.
    I just sprayed it down with WD40, maybe it's just rusted together... I don't know. Any ideas?
    1989 325i m50b25tu swap
    1989 325i (sold)
  • mr.vang
    • 4371
    pitman or leave the nut on top end of the thread and hammer it, then go to junk yard and grab two new nuts to replace it.
    • S62
      • Nov 2011
      • 262
      ball joint seperator, I love this tool
      http://www.harborfreight.com/3-4-qua...tor-99849.html
      • stillkotd
        • May 2011
        • 127
        I will look for one of these tomorrow. That definitely looks like a "work smarter, not harder" kind of a tool. I like.
        1989 325i (sold)
        • Teaguer
          • Sep 2004
          • 6167
          These threads always amuse me! :rofl:
            • 37833
            Originally posted by teaguer
            these threads always amuse me! :rofl:
            +1
            Grover Beach, California
            BimmerHeads.com
            • stillkotd
              • May 2011
              • 127
              Sometimes we all just need someone to point out the obvious. :drink:
              1989 325i (sold)
              • 110stx
                • Sep 2011
                • 253
                This. ^^^
                I tried one for removing the struts and it changed my life.
                d.hitchcock
                STX e30
                No. 10/110 STX: 1989 325i
                DD: 1991 318is slicktop
                SHAZAM, GOMER, LOOK AHEAD.
                • rasalghoul
                  • 24
                  torch+BFH or air hammer works on the most stubborn of joints
                  • FunfGan
                    • Jan 2011
                    • 4958
                    Same issue, bent 2 forks trying to remove it, even after taking a bfh to it. Case in short: buy a separator.
                    Go here be happy!
                    Ratchet Garage e30 V8 build.
                    • AbsorbantNut
                      Non faccio funzionare questa merda
                      • Jun 2010
                      • 2491
                      Have a friend put weight on a pry bar trying to separate it and then use a hammer and smack the strut housing. Thats how I got mine out, took a lot of cursing too:p
                      '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
                      • immajackuup
                        • Dec 2010
                        • 1132
                        fuge that!!
                        this one is better
                        http://www.harborfreight.com/5-piece...set-66686.html
                        done some many ball joint separate with this took kit.
                        • Sputnik
                          • Jan 2010
                          • 808
                          If your going to use one of these ball joint seperators leave the nut still on the tip of the balljoint and its not always the best to tighten until it pops, its better if you tighten it hard then hit the top with a bfh.
                          this tool is a F***ing lifesaver
                          • AE86
                            • 272
                            Watch this VIDEO, study its method, buy some PB Blaster & ear plugs, eat yourself a sandwich, wait an hour.......
                            hold on to your balls and go for it...
                            WTB: Diamond Schwartz Hood
                            • TobyB
                              • 5280
                              this. And a hammer. And some safety glasses. AND tie it down so it doesn't fly
                              across the room when it finally pops free.
                              t
