Suspension question
  • AXMalex
    • Sep 2011
    • 40
    Suspension question
    will these KYB shocks work with these springs
    http://www.ebay.com/itm/KYB-4-SHOCKS...#ht_500wt_1025
    sorry if its a noob question
    BUYING COILOVERS
    (http://www.r3vlimited.com/board/showthread.php?t=225426)
  • mr ilia
    • May 2011
    • 582
    If the parts are for your car, then i would say it will work. Kyb are ok quality part, but i cant speak for the coils, as i'm not familiar with product.
    • Exodus_2pt0
      • 5943
      You know those springs will require cutting the spring perch off of the strut housing and welding the threaded collar on....
      No E30 Club
      • SkiFree
        • Jun 2011
        • 2766
        NO, that no-name cosmo vendor is selling you components needed for a coilover setup (2.5" spring diameter), you've got to cut and weld them on (at least for the fronts).
        ADAMS Autosport
        • DRTSRFR
          • May 2008
          • 1836
          Our coilover sleeves, damper hats, and spring seats are made from high quality billet T6061
          Now, how are you going to weld the sleeves to the housings???
          It's a typical low quality conversion. You don't need to weld anything. You can trim the factory perch so the adjuster will thread all the way down.
          But high quality billet? NO
          Suspension tips here...
          http://www.r3vlimited.com/board/album.php?albumid=757
          • AXMalex
            • Sep 2011
            • 40
            i wanted to get ground controls, but i cant afford it at the moment
            what combo should i go with for a good drop and daily driving?
            BUYING COILOVERS
            • TobyB
              • 5264
              I dunno- that ebay pic looks like it's generic. Even the factory uses inserts for the E30...
              ..and those look like e36 struts anyway...
              but yeah, if the KYB's are inserts, not struts, you do still have to 'perch' the
              sleeves.
              And yes, the parts wouldn't be a bad match.
              t
              • devon.818
                • Feb 2011
                • 2937
                German engineering, or Einstein on this forum, sells coilovers using what lOojs to be similar quality(cough cough just as good) as GC.
                He sells for I believe 320$ shipped for f and r. Custome spring rates he gas too.
                Can't beat that.
                • devon.818
                  • Feb 2011
                  • 2937
                  Can't beat that.
                  • mr ilia
                    • May 2011
                    • 582
                    kyb is a straight swap from the stock shock, no cutting or welding required.
                    Also, you can try STAGG brand off ebay. This is what I got installed.... these are the same gas shocks used in the JOM coilover set.
