Cutting Down Bilstein Internal Bump Stops
    • 37829
    We just did this to a friend's car a week or so ago, it was very easy and it rides great on Bilstein HD with IE3 springs.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • AE86
      • 272
      How much did you cut?
      WTB: Diamond Schwartz Hood
      • Ryann
        • 3350
        Originally posted by lj851
        it's pressed in , not screwed in. Get a chisel or similar and gently drive the silver cap off. It is attached to the damper rod and you are not entering the fluid cavity (pressurized) part of the strut. This will expose the bump stop, remove however much you want with a razor blade.
        Edit: Also, the yellow outer shell is just a covering, it's inner surface is not what the shock piston rides on (seals against) like a conventional strut. Gently clamping it in a vice is fine.
        nice!
          • 37829
          Not my picture but this is how we did it:
          Grover Beach, CA
          www.BimmerHeads.com
          • eLKuRLy
            • Oct 2007
            • 360
            bumping this thread to find out how much are people cutting off on ix HD's?
            • randomtask37
              • 3154
              Maybe a dumb question, but do billy sport rears have internal bump stops also?
              98 M3/4/5
              • jeffnhiscars
                • Jun 2011
                • 6010
                I cant say with 100% certainty that they dont, but the rear is a shock vs a strut and so would not come apart the same way. I have also never heard of one bottoming which is the only reason to consider cutting it down.
                Alice the Time Capsule
