Sean's crossweights thread
  • priapism
    • 1182
    Trying to scale the SE30.
    Before:
    Okay, so lower = lighter, right? So I put a 7.5mm spring pad in the right rear. Should weight that corner better, right?
    After:
    20lbs lighter. Huh?
    -Sean : 91 Calypso 325i : Castro Motorsports SoCal Spec E30 #33
    To correct the cross error you want to raise the right rear corner, which would mean thicker spring pads on that corner. On the rear wheels you can stack spring pads.
    • priapism
      • 1182
      Right, that's what I did. And it got LIGHTER.
        That could happen because you did not also put a thicker pad in the left front. Usually you work the wheels on both ends of the light diagonal. You might also remove all the pads on the other diagonal.
        • priapism
          • 1182
          I have pads in both front corners. I have to add to both corners? The LF has always been very heavy.
          It's such a pain to get those front ones in and out though. Should I just cut the RF one out?
            I'd remove the pads from the RF to LR diagonal and add pads to the LF to RR diagonal. If this is a race car that is carrying ballast, I'd put that ballast next to the RR shock tower.
            • TobyB
              • 5280
              ...and I'd check the scale wiring, too... because I made that mistake once,
              and it does, in fact, drive you insane.
              Yeah, +1, remove spacers from heavy wheels, add spacers to light wheels....
              Threaded collars make life so much better... if they're legal. Not in sE30, tho, right?
              t
