How do I go lower in the rear?
  • Genkboy8o8
    • 171
    Alright guys, haters are gonna hate, but hey, it's my car.
    So I have AST4100's on my car and just installed my rear spring/strut. To my surprise, with the springs winded down to the lowest setting, the car was sitting higher than my cut eibach springs... weird.
    Any ideas how i can go lower in the rear?
    Does the spring rate really make a difference? I think right now its H&R either 600 or 800. And the spring is literally like 5" or 6" tall? Its a really small spring. Help me?
    Video I made of my car: http://www.youtube.com/watch?v=WGg8GixF8Ds
    • 37833
    Remove the adjuster.
    Grover Beach, California
    BimmerHeads.com
    • LJ851
      • 7919
      Remove the spring, or
      Hamburgers for girlfriend
      Lorin
      The M30 is God's engine.
      • nomansland92
        • 1657
        A thousand pounds of bricks in the truck ;) or different springs
        IX being restored here
        Ix turbo build here
        • M-technik-3
          • 18946
          What was the reason for choosing the AST's? They are for the most part designed for competition vs a stanced look.
          • Genkboy8o8
            • 171
            Reason I went with AST is for the performance. I take the time to readjust them for the track so that's my defense. I'm also into the stance scene.
            When I remove the adjuster, it gets kind of scary because the spring is not sitting nicely in the spring seats... and plus, the spring is so small, if I raise the rear and release the pressure from the shocks, the spring will literally fall out.
            Any springs you guys recommend thatll help me go lower?
              • 37833
              I believe GC and IE both sell pads to fit the 2.5" coilover spring in there without an adjuster.
              Most slammed people are running a 2.5" diameter coilover spring in their desired length and rate.
              BimmerHeads.com
              • Teaguer
                • Sep 2004
                • 6167
                ^ Yep.
                To get the low look you have to run your desired rate and 4-5" spring without the adjuster.
                Don't worry about it falling out, it wont. Unless you are doing Dukes of Hazzard type flights you will be ok.
                • einstein57
                  • Jun 2007
                  • 10780
                  IE centering pad should get you good to go. If you want new springs i have 4.5" 650 springs that are tapered on top to use the factory spring pad. The great part is they are made by the same company AST uses.
                  www.gecoils.com
                  • Genkboy8o8
                    • 171
                    Are these the spring pads you guys are talking about?
                    And how much are you selling the springs for, I might be interested.
