Best rear strut mount?
  • fast91
    • May 2011
    • 77
    What's the best rear strut mount? I know ie has a set but I was wondering if there was anything better. For street maybe track use, going to have bilstein sports.
    Reason for my asking is I just picked up my wheels for the 5lug swap. E38 style 5s! And struts are next on my list.
  • Jand3rson
    • 37587
    A short bungee cord.
    • Pantless Spency
      It's McRib time!!!
      • Feb 2011
      • 7283
      something thick and strong made out of metal.
      those usually work good.
      • davem
        • Jun 2010
        • 705
        there aren't any struts in the rear, do you mean shock mounts?
        i have bilstein sport and h&r and use the e46 m3 cabrio mounts which are commonly used to replace worn out factory style ones
        • JTDay
          • Dec 2009
          • 521
          ^i used e46 cabrio mounts when i did suspension on my e30. OEM and cheap.
          Past: 1987 325iS, Bilsteins - HR Sports
          Present: 1999 M3, Koni Yellows - HR Sports - GC Camber Plates - UUC Swaybars - UUC SSK - AFE Intake - Stromung Catback
          2009 Mazdaspeed3, Short Ram Intake - Turbo Inlet Pipe - 2nd cat Delete - Catback - Fuel Pump Internals - Cobb Accessport - Stratified E30 tune - 294/342 - SPC Camber Arms - CPE Rear Motor Mount
          • jw 325ic
            • Sep 2006
            • 1360
            bmp or tms aluminum/urethane mounts. they havent gone out since 2005.
              • 37833
              I like the Meyle HD mounts, excellent for the price.
              Grover Beach, California
              BimmerHeads.com
              • fast91
                • May 2011
                • 77
                Thats my seat belt.
                You know I was thinking of going for light weight plastic to save weight. But it has to be strong right? Maybe carbon fiber?????
                Go troll something else.
                And yeah I meant shock mounts. I was in the moment when I posted this after aquiring my wheels.
                Thanks for the input everyone else.
                • Dagamus(NM)
                  • 621
                  I got my last set from AKG. They are expensive, but well made. I probably would not have spent as much but I needed them to go with the Koni's my wife got me for x-mas.
                  http://www.akgmotorsport.com/catalog...ion%2FBushings
                  For the longest I ran e46 cabrio mounts with the z3 plates. For Bilstein this is most likely what you want unless you have money burning a hole in your pocket.
                  Gun control means using both hands
                  Sex, Drugs, Rock 'n roll. Pick two.
                  • KenC
                    King of Kegstands
                    • 14396
                    These are what I ran in my e30. They're pretty beefy.
                    Originally posted by Gruelius
                    • Holland
                      • Nov 2008
                      • 7212
                      I'm using GC mounts paired with Bilstein sports, they do well.
                      Originally posted by DEV0 E30
                      • flash 23
                        • 904
                        Re
                        • idickers
                          • Sep 2011
                          • 92
                          I like the Rogue Engineering mounts. I found the Ireland urethane mounts to harsh for the street, and the reinforced rubber mounts on the Rogue are a nice compromise. Plus, with their inverted bolt design, you can attach the rear shocks from the wheel well, without having to take apart the trunk to get at the bolts.
                          http://http://www.rogueengineering.com/rogue/S_BUSH/RSM.html
                          • frankenbeemer
                            • Sep 2009
                            • 2260
                            Good deal here:
                            Don't buy an e30
                            They're stupid
                            1989 325is Raged on then sold.
                            1988 325 SETA 2DR Beaten to death, then parted.
                            1988 325 SETA 4DR Parted.
                            1990 325i Cabrio Daily'd, then stored 2 yrs ago.
                            • Wanganstyle
                              • 2828
                              ditto. Its not uncomfortable for street use, NVH does go up a little bit though vs using E46M mounts
