whats the secret to remove this nut (front shock)
  • flash 23
    • 904
    Originally posted by devon.818
    spring compressors aren't needed, just lay it on the ground on its side pointing away from you so when it POPS you dont get hit lol
    reading is fundamental. im just saying if u want to go the spring compressor route, u may also. :read:
    • immajackuup
      • Dec 2010
      • 1132
      Impact gun.
      that or this
      • io_RobbieRodgers
        • Nov 2011
        • 57
        The truly easiest way to remove these with hand tools, for future reference, is with the proper socket and two vice grips. Good vice grips. When I did my second suspension swap in December my vice grips were suddenly missing, and I spent two hours on each side with a P.O.S. Harbor Freight needlenose and a box-wrench. Miserable business.
        Anyways, slip the socket over the nut, then open up one of your vice grips and clamp it around the socket. This leaves the top of the nut open to put the appropriate sized allen-key. It's advisable to do this with the strut out of the car. Twist the vice-grip and allen key in opposite directions If the allen key strips, which is very probable, use your back up pair of vicegrips around the outside of the spindle.
        On the rear struts, you will need the second pair of vice-grips because the spindle doesn't use an allen key.
        Reformed E34 addict. 1993 525i/5 - 1995 525i/5 - 1991 318i/C
        • seatown88
          • 331
          impact wrench works great, 5 seconds each side(assemblies removed from the car, using spring compressors to remove spring pressure). It's the way I prefer to remove them. That being said they probably could be removed on the car with a jack compressing the assembly, and slowing lowering the jack when the nut is removed.
          io RobbieRodgers is right though, the engineered "proper" way to remove the nut is using hand tools and hold the strut shaft with an allen while spinning the nut. There are socket sets that make it easier(pictured above) that using vice grips, but vice grips are a cheaper solution and worth the struggles if you are only doing this once or twice.
          • 5Toes
            • 9836
            Wrap towel around vise grip jaws and around the shaft of the shock, spin top nut
            You need a deep socket too by the way. 19mm
            • borrihong
              • 134
              Originally posted by jaywood
              I put the whole assembly on the ground and held it with my foot. It eventually came off.
              yep, lay it on the ground, hit it with the impact. hold it like your going to shoot it with a gun, it WILL kick.
              "evil always prevails....because good is dumb"
              • b*saint
                • 3794
                impact gun or the right tool.
                Ma che cazzo state dicendo? :|
                • Simon S
                  • Oct 2004
                  • 3758
                  -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    Originally posted by Simon S
                    I tried that but mine has a hex head. The only socket I had that would fit through the 1\2 socket was 1/4 drive 8mm deep and it split (thank you Crafstman for your warranty).
                    In the end I used a socket and ratchet on top and held the very top of the strut shaft with a pipe wrench, spring compressor in place.
                    Alice the Time Capsule
                    • deutschman
                      • May 2008
                      • 5958
                      Impact gun.
                      But the vice grip method will work as well. Just make sure you have the spring compressed or it will hit you in the face and brake all your teeth and be a pain to get back in.
                      • nrubenstein
                        • 3148
                        Originally posted by MaxBell
                        MAKE SURE you have a spring compresser holding the springs. Otherwise when that nut comes off they will FLY apart, and you could injure yourself.
                        Yeah, you need to be a little bit cautious, but I don't waste my time with spring compressors for removal.
                        2002 BMW M3 Alpinweiß/Black
                        1999 323i GTS2 Alpinweiß
                        1995 M3 Dakargelb/Black
                        - S50B32/S6S420G/3.91
                        1990 325is Brilliantrot/Tan
                        1989 M3 Alpinweiß/Black
                        • andrewm
                          • 456
                          I used to know a guy who did it without a spring compressor.
                          1987 Delphin 325e Sedan - Natalie
                          1990 325i 24v
                          1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
                          • b*saint
                            • 3794
                            He died?
                            • idanity
                              • Jun 2006
                              • 775
                              Originally posted by b*saint
                              He died?
                              or, is he a girl now ?
                              3 pedal club
                              200,k+ club
                              cabrio club
                              port-matched- polished- purring www.BMWpark.org
                              </div>
                              linux since 1999
                              • BrassDrummer
                                • Feb 2012
                                • 68
                                I ask Chuck Norris to remove it for me.
