Sitting high for IE stg3
    • 34847
    the camber plates are causing a lot of it. something with a shorter stack height, like GC or vorshlag, would be much better. then you wouldn't have to cut your springs.
    • SkiFree
      • Jun 2011
      • 2766
      As quoted from the website.
      "Installation note Since you are not removing the upper strut bearings with the use of this mount (Like with our street/track and race plates) you will be adding to the stack height of the suspension. The thickness of the plate is 3/8" thick."
      The brand of camber plate is not as important as to the way it's constructed. The IE street-plate is for those looking for a fairly economic solution, and it's priced as such. It's not going to feature a piece that replaces the upper spring perch (and thus shorten the overall stack height) like the more expensive IE street/track or race, Ground Control, Vorshlag, etc.
      ADAMS Autosport
        • 34847
        right. it's adding to his ride height up front - that was my point. :)
        • SkiFree
          • Jun 2011
          • 2766
          I swear we are in parallel universes sometimes.
          ADAMS Autosport
