What Control arm bushings are YOU using?
  • Beej '86 325es
    • 2639
    regular Powerflex bushings. Had them for about 5 years now and still work great. Design makes them impossible to pop out of the lollypop.
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • golde30
      • 11464
      Originally posted by nando
      M3 offset (rubber)
      IG: @Baye30
      • gstuning
        • 833
        THR and they are awesome, can´t judge on the others as I haven´t had them,
        May be just as good
        Gunni
        @ Prodrive / Aston Martin Racing
        • JRKOUPE
          • Dec 2004
          • 3159
          to the original poster........poly is fine for street..Ive used em for yrs.....you wont notice much harshensss increase...if at all.
          If you have any concerns.....go w/ Mystikals choice........oe 95 m3 offset which are same as e 30 M3........offset gives you more caster......nothing else. Better hi spd stability , no change to camber as most people think . THR is pure overkill for a non tracked often street driven car.....but a great product none the less......
          depends what your goals are...
          • hydrospeed2000
            • May 2005
            • 54
            [QUOTE] THR is pure overkill for a non tracked often street driven car.....but a great product none the less......QUOTE]
            THR,, simply put, no frills, pure geometry, complete return on investment. I have them on my 318is and besides the slow ass M42 under the hood it feels and responds like the ultimate should.
            Rubber= bad, Can't replace (except for the whole unit)
            THR bushing= good, easily replaced (if they ever need to be)
            Anonymity on the internet is courage for the people who have none. You know who you are.
            • JRKOUPE
              • Dec 2004
              • 3159
              [QUOTE=hydrospeed2000]
              I agree..great product
              • RCWells
                • 3589
                Well as some of you know, I DO have the THR cabs which is the real reason I posed the questions in the first place.
                Since the changes,(H&R race springs, THR cabs, and 17" wheels/tires)and unfortunately they all happened at once so it's hard to determine the source of the problem, my front end at speed has felt loose and darty.
                Now to preface this: I installed new Lem control arms and outer tie rods all at the same time the rest of the changes occurred. I sanded the shit outta the ends of the CAs(still pop like mad) and then once everything was together, went and had a front end alignment done at a local tire shop. So yes, the front end is aligned, "professionally" so.
                Anybody here have any ideas as to why my front end has gone loose on me? I was initially leaning toward blaming the cabs, but have since discussed it with a few people that think it may be the alignment. BUT, if the alignment was done to "spec", then why would the front end be all darty and loose?
                Anybody?
                [THE 501 club - Founding Member]
                • DarkWing6
                  • Apr 2004
                  • 7144
                  Originally posted by rede30
                  I have the treehouse monsters and love them
                  I agree. I have no spring pads up front and my suspension is loud as hell, but I love the feel and thats all that matters.
                  • Digitalwave
                    is a poseur
                    • 6282
                    Anybody?
                    Was your car properly aligned before the new suspension? That might just be the way it should be, you could have had some toe in or out before. Or maybe they dialed in some toe in or out at the shop, did you ask when they did it?
                    I have urethane offset CABs and no spring pads and there is no noise in the front end. My springs are so short the can sag about 5" at rest as well.
                    RISING EDGE
                    • bimmer8604
                      • 3017
                      Something to think about, how did you tighten down all your suspension stuff? If you left it all hanging, you could have preloaded the whole front end which will cause memory steer.
                      kyle
                      1988 M3, 97 840, 99 XJ
                      DILLIGAF
                      • Axxe
                        • Aug 2004
                        • 3355
                        M3 offset rubber.
                        Keep it slideways!!
                        • Digitalwave
                          is a poseur
                          • 6282
                          kyle
                          Preloaded the CABs you mean? They slide freely on the control arm.
                          RISING EDGE
                          • E30 Wagen
                            So, he's saying is that offset, which gives you more camber, provides better high speed stability? How do it affect tire wear?
                            • Digitalwave
                              is a poseur
                              • 6282
                              It increases castor, not camber. It doesn't affect tire wear.
                              RISING EDGE
                              • RCWells
                                • 3589
                                I assume that is was aligned properly, but not sure of it. Looking at the front dead on, IF anything, it's set toe-out. Not much if at all, but it would err in that direction.
                                As for the CABs, I tightened them AFTER we had dropped the car back to the ground so as NOT to preload them. The tie rod outers and control arms were all tightened while still in the air.
                                I don't know yet, but the new bushing material will be here in a few days, I will swap it out and go from there.
                                Thanks for the input.
