Shock valving #'s
  • eLKuRLy
    • Oct 2007
    • 360
    Shock valving #'s
    I've searched and have found very little info in stock shock valving #'s. We need valving #'s that we can use as a reference.
    You read, match you springs to your shocks. So what numbers are the shocks? I know you can have your shocks re-valved but if I can run a shock/strut out of the box without re-valving, why not?
    example
    SHOCK --- Spring rate (lbs)
    ix Bilstein Hd shocks - 250-350lbs (only example!!!)
    bilstein sports - ????
    Camaro (r) - ???
    mr2 -
    koni sport (f or r) -
    Hope it makes for good topic.
  • eLKuRLy
    • Oct 2007
    • 360
    ....guess not. haha
    • E30_fiend
      • Apr 2006
      • 7348
      I think this is a great topic honestly. Unfortunately, I have nothing to contribute but I'm subscribed
      Taylor
      • eLKuRLy
        • Oct 2007
        • 360
        yup. me neither, but thought it would be a good topic
        • Northern
          I like cupcakes & sh!tboxes
          • 5284
          I always thought that when you sent your shocks to be revalved you just told them what spring rate you wanted them revalved for and they did it.
          Originally posted by priapism
          Originally posted by shameson
          • bmwguy325is
            • May 2011
            • 1263
            I could not find my shock dyno plots.
            However. With most off the shelf shocks you can call the shock maker and they can tell you want springs they can handle.
            But yes as mentioned above if you get shock re-valved thy can tailor them to your spring rates.
            The kicker is the shock dyno how repeatable are the "clicks" on the shocks?
            Oh and if you buy the Koni sports from a good place they can valve them for you
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • Komzorz
              • Jun 2011
              • 332
              I have a couple good links on this. First, some Bilstein stuff I'm shamelessly reposting for the sake of archival:
              http://www.mye28.com/viewtopic.php?t=61206
              Re: <E30><E28><E24><02> Shock Damping Numbers (Bilstein)
              * Subject: Re: <E30><E28><E24><02> Shock Damping Numbers (Bilstein)
              * Date: Wed, 02 Dec 1998 17:24:10 -0500
              It's nice to see the shock questions and great answers (especially
              Al Jenab's). Here's some E30 Bilstein shock data and I've also
              included one of my shock posts from last year which may help.
              It seems that E30 Bilstein Sports and HD are the same except for
              the shorter length of the Sport. Note that E30 front struts come
              in two sizes (P36-36mm piston and P30-30mm piston) depending on
              the model and year, but the damping numbers are the same.
              E30 3 series 325e/es, i/is, M3
              (3 series 87-91, 318i thru 86, front has 30mm piston, P30)
              rebound / compression force at 52 cm/sec
              Newton pound-force
              N lbf (0.2248 x N)
              Front:
              P36 0132 Sport 2220/850 499 / 191
              (P30 0133 Sport) 2220/850 499 / 191
              P36 0136 HD 2220/850 499 / 191
              (P30 0128 HD) 2220/850 499 / 191
              Rear:
              B36 2027 1475 Sport 1650/565 371 / 127
              B36 2028 0720 HD 1650/565 371 / 127
              ...old bmw-digest post on shocks...
              Subject: Re: <E28><E24><02> Shock Damping Numbers (Bilstein)
              Ed Mellinger writes:
              >we can either talk about religion, or we can talk about shocks...
              >Does anyone know of a source of actual numbers that would allow
              >an intercomparison between, say, Bilstein, Boge, and KYB shocks
              >for an E28? I mean, there should be a spec for compression, and
              >one for rebound, in some kind of units like newtons per meter per
              >second...
              Ed,
              Yes, I have some actual damping numbers from Bilstein and I'll
              attempt some rough estimates on the Boge and Koni shocks.
              My Bilstein information is better than the other brands because I
              purchased Bilstein Sports (and Dinan springs) and both Bilstein
              reps have been extremely helpful.
              East Coast Rep (CT), Scott MacDonald 203.265-2854
              West Coast Rep (CA), Cleve Hardaker 619.453-7723
              Shock Damping Numbers, Dyno Speeds
              Shock damping is the force required to move the shock shaft at
              a particular (shock piston) speed. Increase the speed and the
              force increases, so specific damping numbers are always measured
              at a specific speed.
              A complete shock damping curve can be plotted by measuring the
              force at various speeds with a shock dyno. Damping force is
              measured in newtons (N), kilopond (kp), or pound-force (lbf).
              N = 0.101972 kp = 0.224809 lbf.
              Shock piston speed is measured in cm/sec or inch/sec.
              Until reading Paul Haney's shock dyno description in his
              "Inside Racing Technology" book, I was confused by the different
              ways of specifying shock speed. Some references talked about
              speed in terms of shock dyno stroke and rpm, while most used
              cm/sec or inch/sec. I couldn't correlate the two using mean
              shock piston speed (i.e. mean speed = 2 x stroke x rpm).
              Haney's explanation of the convention used for shock dynos confirmed
              that both methods work out to the same cm/sec or inch/sec speeds.
              rpm x stroke x pi = speed
              So for a shock dyno at 100 rpm and 100mm (10cm) stroke:
              100 rev min 10cm x 3.14
              ------- x ------ x ----------- = 52.36 cm/sec
              min 60 sec rev
              Typical shock dyno rpm, stroke, and resulting speed:
              Stroke Speed Speed
              Rpm mm cm/sec inch/sec
              10 100 5.2 2.1
              25 100 13.1 5.2
              50 100 26.2 10.3
              75 100 39.3 15.5
              100 100 52.4 20.6
              200 100 104.7 41.1
              100 25 13.1 5.2
              100 50 26.2 10.3
              100 75 39.3 15.5
              100 100 52.4 20.6
              E28, E24 Bilstein Numbers
              Bilstein shocks usually come in three valving choices:
              Comfort = Original ride quality
              Heavy Duty = Firmer than original
              Sport = Firmest (shorter shaft for shorter/stiffer springs)
              The part numbers work like this:
              P36: P = Strut insert, 36 = piston diameter in mm.
              B46: B = Shock, 46 = piston diameter in mm.
              The last four numbers (e.g. P36 0243, for E28 sport front strut)
              give the model applicability and valving.
              All the Bilstein reference damping numbers are for 52 cm/sec,
              a relatively high speed. Obviously one number can't convey
              what the whole damping curve looks like, but it gives some feel
              for relative values between the Comfort, Heavy Duty (HD), and
              Sport valving.
              Bilstein E28 5 series 82-88, E24 6 series 83-on
              Newton pound-force
              N lbf (0.2248 x N)
              Front:
              P36 0243 Sport 2900 / 950 652 / 214
              P36 0233 HD 2860 / 650 643 / 146
              P36 0239 Comfort 1790 / 650 402 / 146
              Rear:
              B46 0607 Sport 1605 / 805 361 / 181
              B46 0608 HD 1605 / 805 361 / 181
              B46 0610 Comfort 1590 / 770 358 / 173
              Notice how close the numbers are between the HD and Sport, while
              the Comfort front damping is significantly softer. The difference
              varies between car models.
              General Bilstein Info, '02 Numbers
              Bilstein seems to have changed their philosophy through the years.
              The earlier cars, such as the 'O2, E12 528i, and E21 320i, have much
              stiffer damping on the Sport shock, while the later E30 and E34 models
              have the same damping numbers for the Sport and HD. The E28 is
              somewhere between with little difference except for front compression
              damping.
              Taking a look at the 'O2 numbers as an example of an older model:
              <02> 1600, 2002
              Newton pound-force
              N lbf (0.2248 x N)
              Front:
              P30 0025 Sport 2150 /1110 483 / 250
              P30 0023 HD 1660 / 780 373 / 175
              Rear:
              B46 0118 Sport 2351 / 664 529 / 149
              B46 0803 HD 1210 / 575 272 / 129
              The 94&percnt; increase in rear rebound damping jumps out at me. That
              may help explain why many experienced BMW owners (probably former
              '02 Sport users) say to never use Sports on the street. They probably
              assume that all BMW Bilstein Sports are equally stiff, but the later
              models are much more reasonable for street use.
              Comparison to Boge and Koni
              The original Boge shocks on most E28s should be close to the Bilstein
              Comfort valving (E28 M5s use front gas charged Boges and rear
              load-leveling Fichtel and Sachs shocks. The E28 535is uses Bilstein
              Mtechnic shocks with damping somewhere between the Comfort and HD).
              Boge turbo gas shocks should be a little stiffer than the standard
              model.
              Koni shocks are rebound damping adjustable only, so I assume the
              compression damping is similar to the Bilstein Sport. The typical
              starting rebound adjustment is 0.75 turns out of 2.5 turns total,
              so they probably can be adjusted for stiffer rebound damping than
              the Bilstein.
              E28, E24 Shock Summary in order of increasing price
              1. Standard OEM Boge. Twin tube (inner and outer tube),
              non-adjustable shocks. Similar to Bilstein Comfort valving.
              p/n front 32 836 0, rear 32 912 2
              2. Boge Turbo Gas. Low pressure gas charged, twin tube, non-adjustable
              shocks. Upgrade from standard Boge, firmer damping.
              p/n front 32 839 F, rear 32 279 F
              3. Bilstein. Monotube (single tube), high pressure gas charged
              non-adjustable shocks. E28 rear HD shocks have three height
              adjustment grooves 10mm apart, while Sports have six adjustment
              grooves. Sport shocks have 0.75 inch shorter shafts so
              shorter/stiffer springs remain seated when the suspension is
              unloaded.
              p/n (see numbers above in Bilstein table)
              4. Koni. Low pressure gas charged, twin tube adjustable shocks.
              Rebound adjustment only. Probably can adjust rebound stiffer
              than Bilstein Sport. E28 rear shocks have two height adjustment
              grooves. Front rebound damping can be quickly adjusted. E28
              rear shocks must be removed for rebound adjustment (remove
              spring, push shock rod down all the way and turn to adjust).
              p/n front 8641-1080, rear 8240-1010
              Take your choice. Any of these shocks should be fine. Remember
              that Boge has been BMW original equipment for years.
              Bilstein and Koni are the highest price and highest quality.
              Koni puts the extra cost into making the shock adjustable while
              Bilstein uses the technically superior monotube design.
              Pete Read
              '88 M5
              Arlington, VA
              And I also had a link to some guy that graphed the differences in damping rates between Koni Yellows (full soft and full hard) and Bilstein Sports, but I can't find it at the moment.
              '87 325is - Schwarz/Schwarz
              • Vivek
                attention whore/retard/bitch
                • 6167
                Originally posted by eLKuRLy
                Camaro (r) -
                mr2 -
                Any info?
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • TobyB
                  • 5298
                  Nope.
                  Because not very many of us, me included, has a shock dyno in the garage.
                  If you look at the people who really use shocks, they do. But they race. And their
                  numbers don't make sense to the rest of us.
                  Me, I tell GC what I'm using the car for, and they send back yellow things that
                  I bolt into the car and twist the little knob on the ends until I don't go any faster,
                  then I stop twisting. And maybe untwist a little bit until I go slower, then retwist just a click.
                  But that's as scientific as I get.
                  Stock cars use shocks rated from 2 to 9 in bump and rebound. 2 is softer than 6.
                  The rest you figure out by twisting until you don't go any faster.
                  t
