Should I shorten strut housing?
  • nokincy
    • Feb 2012
    • 302
    I just purchased ground control coilovers with 450f/600r rates; I'm going to be using them with 325i not ix or g60 Bilstein sports up front and KYB Camaro shocks in the rear. My question is; is it advised that I shorten the front strut housing with the Bilstein shocks I am using even though they are not shorter than stock? I've searched and there is too much conflicting information. I'm not looking to hellaslam the car, just a slight drop however; if I can gain travel / improve handling by shortening the housing then I will.
  • reelizmpro
    • 9552
    How will u shorten the housing without using shorter shocks?
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • nokincy
      • Feb 2012
      • 302
      Exactly my question, I didn't think it was possible but some people stated to shorten them regardless. As well as the GC instructions.
      • kronus
        • Apr 2008
        • 13032
        the people that shorten strut housings use shorter shocks. You will not be able to install a 325i damper in a shortened strut housing.
        cars beep boop
        • nokincy
          • Feb 2012
          • 302
          Thanks for the clarification.
          • wakdog
            • 223
            You could weld the spring perch lower but to use any of the effective lower ride height you would probably be sitting on your bump stops...
            90 318i M62B44 OBD1
            02 530i Touring (Airlift 3P)
            • ToPLeSS(e30)FeinD
              • Jul 2011
              • 2813
              for reference, i recently shortened my housings on the vert and am running the KYB AGX adjustables and im prettty low but the ride quality is unprecedented. 450/650 GE coils
              '89 Delphin 2.8 Cabrio
              '94 Yamaha FZR 600
              Originally posted by FlexdXJ
              Is that thing on air?
              • yeaseth
                • Jul 2011
                • 302
                thats like asking if can you fit a square peg into a round hole... I guess you could if the square peg was smaller then the hole but you get the point
                benvideoproductions.com
                http://www.youtube.com/watch?v=617yNrOrRfo&
