I know its common when replacing the control arm bushings to get the m3 offset versions. From what I've seen its suppose to help negative camber from a lowered car. Currently my car is stock height (cabriolet btw) but will be doing the H&R Touring cup kit within the next 12 months. Is there any other advantages to getting the offsets? I have a bad control arm so while replacing it I was going to do the bushings...
Control arm bushings
Tags: None
If you are changing the CA's of course you need new bushings. I just swapped my Cabrio to the offsets (when I did the CA's tierods & e36 swap) and the offsets change castor not camber, which essentially makes the car want to go straight. This gives you better high speed stability but IMHO also adds a bit to steering effort (since the car is saying "Im enjoying going straight")..not enough to be concerned about so def a good mod.I know its common when replacing the control arm bushings to get the m3 offset versions. From what I've seen its suppose to help negative camber from a lowered car. Currently my car is stock height (cabriolet btw) but will be doing the H&R Touring cup kit within the next 12 months. Is there any other advantages to getting the offsets? I have a bad control arm so while replacing it I was going to do the bushings...Seat Shocks....I have passed the baton to John Christy from Ninestitch. Email John or Garrett at ninestitch1@gmail.com
Alice the Time Capsule
87 Zinno Cabrio barn find 98k and still smells like a barn. Build thread http://www.r3vlimited.com/board/show...20#post3455220Comment
