Alright will do
E30 Megan Coilovers thread!
i have pics and vids as well if anyone is interested. install was smooth as can be. I do run 3mm spacers with TRM c1s 15x8 tire size 205/50/15. my current setup is not all the way down with the camber plates set slightly to positive camber so that the neg camber up front is less severe. the dampening setting is 12 clicks up front and 16 in the back and its plenty stiff enough. vids and pics to come!
vids didnt come out nice but the go pro will be mounted soon for some different driving footage. overall I am very satisfied with performace and streetability. I drive to school a few times a semester and its 3 hours each way and I feel these will not be a problem. install was very easy and a local fab guy who runs the exhaust shop did the welding. took all of 3 minutes and 10 dollars.
theres still about 2 inches of drop but those wheels dont allow for much. will prob just get a 6" spring for the front. White 318 is my fathers. its stock to give you an idea.
By all means, post em up!
ZF320 | M50 Mani | TRM + 21.5lb Injectors + 3.5in MAF | E36 M3 Rack/Driveshaft | Megan Coilovers | 002R/452's
In the works: UUC Evo 3/DSSR, JB Racing lightweight Flywheel, Shrick cams, BBK (yet to be determined)
I NEED A WINGLESS AW TRUNK LID PLEASE PM ME IF YOU HAVE ONE!Comment
Thanks for the feedback and photos! Can't wait to see more people getting their suspension set up properly! No more bottoming out for sure!
Just a note, if you're going to make adjustment to the suspension (preload or ride height) while they are already installed on the car, use a little bit of WD40 on the threaded area of the shock body and/or sleeves(rear) and in between the springs and the collars + top hat (where the springs come into contact with) so that it's a lot easier to adjust/spin.Comment
I always just use a jack to take the load off it.Thanks for the feedback and photos! Can't wait to see more people getting their suspension set up properly! No more bottoming out for sure!
dude just cut the tubes and drive around to every shop with a welder until someone does it haha idk about california but over here most shops dont give a crap if you give them a 20 spot. they will just weld it up and call it a day. its structurally a very sound way of mounting.Comment
i have megans installed in my four door....A.K and a friend helped out... they re AWESOME...so BUY IT.... NO.... "ifs...buts...ands" "just do it".I'm a fan of the Megan's for e30's.
Friend has them and they ride and handle so confidently and awesome.
They don't lose shock travel either when adjusting heights like many other traditional coilovers.
GC is great because of the customization of valving, springs, great plates, and cool other products they offer and are race proven. not really about show.
With that said, I'd probably choose the Megan's if I had to do it again becaus I'm not out to win any races and the cost is great
im 232lbs..bigger than most you twigs out there.... it handles amazing... so uncross your legs boys..start walking like a man:)-1986 S50Turbo Sedan (475WHP/417WTQ) Castromotorsport Built (Sold)
-1987 Coupe (17x10.5"/17x14")
Castromotorsport / Buddha_Concept_designs Built *UnderConstruction*
Follow me on Instagram: obes_sebo
For more updates:)
Purchase FeedBack http://www.r3vlimited.com/board/showthread.php?t=278838Comment
This man has a point! I just started tearing out my suspension to make room for the Megans this aft. Hopefully welding happens tomorrow or on thurs.
Another good link for those who aren't understanding the welding portion: http://emeraldcoastdrifters.com/2012...signs-bmw-e30/
Also the Megan USA site has plenty of solid tips for properly setting spring preload, ride height, and general install, including torque specs. It's under the "tech" section.
PS I'm 6'3, 245lbs :finger:Last edited by johnjohnsons54; 07-24-2012, 11:27 PM.
