What size struts is mine? 45mm or 51mm?
  • Rubes
    • 295
    hello all, if anyone can help me? i tried searching before doing this...
    i'm going to do a coilover suspensions setup, but in order to do that... i would need to know what size are my strut. i'm not sure how to measure this and i dont have that special measuring stick (example tool bottom picutre) that can tell me what size are my front strut.
    anyways,
    my car is 1987 325E coupe. maybe that can help?
  • Holland
    • Nov 2008
    • 7212
    51mm. 45mm are 85 and earlier.
    Originally posted by DEV0 E30
    • Thehemiman
      • Apr 2009
      • 533
      What he said.
      1988 325i Vert
      1991 318is Slicktop
      • spike68
        • Apr 2009
        • 1185
        Originally posted by Rubes
        What size struts ARE mine?
        I'm what they call the grammar police.
        I don't even own this car anymore, but I'm too lazy to change the picture.
        • MattAvino
          • Jan 2011
          • 2147
          That tool is called a caliper.
          E30 buildy things
          http://www.r3vlimited.com/board/showthread.php?t=195286
          • flyboyx
            • 8371
            my 88 cabrio had a smaller diameter strut housings. i had to replace them with a set from a later model e30 so i could use the bilsteins i purchased for the car.
            Gigitty Gigitty!!!!
            • reelizmpro
              • 9546
              Obviously u didn't search enough. There are tons of threads just like this.
              88 M3 - LACHSSILBER
              89 M3 - ALPINEWEISS II
              • jeffnhiscars
                • Jun 2011
                • 6011
                Those, oddly enough, must have been swapped in by a PO.
                Alice the Time Capsule
                • bmwguy325is
                  • May 2011
                  • 1263
                  Dial Caliper to be exact thanks.
                  sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
                  The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
                  • reelizmpro
                    • 9546
                    Agreed. Only 84-85 318i and some 86-87 base model 325. No 325i came with smaller struts.
                    88 M3 - LACHSSILBER
                    • Rubes
                      • 295
                      thanks guys!
                      • reelizmpro
                        • 9546
                        These cars are now coming up on 30 years old. Things change so the safest bet is to measure your tubes with a caliper to be sure. Flyboy's 88 vert should have came with 51mm struts...not 45mm.
                        88 M3 - LACHSSILBER
                        • jeffnhiscars
                          • Jun 2011
                          • 6011
                          You dont have to actually measure them. The 45mm housing has an outside thread whereas the 51's have an inside thread. The gland nuts are totally different.
                          • Hellabad
                            • 807
                            Some of the 45mm are inside threaded too. Not sure which ones. This trick works well:
                            Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                            Ground Control Gallery
                            The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                            • Rubes
                              • 295
                              lol perfect! ^^^^^ thanks!
