GC Conversion kit with Boge/Sachs shocks?
  • kickinindian
    • 2327
    is it fine, useless, horrible, good, im just looking to see if i could run new stock shocks with the kit for awhile and would it be fine until i bought Billy Sports?
  • Vivek
    attention whore/retard/bitch
    • 6167
    You'll blow them in a couple days. Depending on how low you are it could be not terrible as long as you're not sitting on the bump stops. My rear shocks have been blown for months but the spring rates sort of make up for it so it's not terribly bouncy. Traction sucks though.
    But if your shocks are original they're probably blown anyways, in which case the higher spring rates would make the overall feel of the car much better.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
    • kickinindian
      • 2327
      they would be new and not slammed just a couple inches wanna be able to lower in the summer and road driving and raise it to stock when im rallying around and winter driving.
        • 37833
        Save up the money and get the Bilsteins.
        Grover Beach, California
        BimmerHeads.com
        • kickinindian
          • 2327
          lol fine :hitler: just was trying to have a temp solution to get the GCs on that much sooner:up:
          • kickinindian
            • 2327
            would KYB gas-A-Just shocks be okay?
            • Vivek
              • 6167
              Ehh sorta. They're really valved for stock setups. If you're going low enough, get Camaro KYB GR2's ($50 for the rear pair) since they're valved for a much heavier car and therefore higher spring rates. But you'll still need to decide on struts. Tokico HP's from an MR2 are a decent solution depending on your spring rates. I'm gonna run 425lb up front and that's what GC recommended.
              • kickinindian
                • 2327
                i was thinking doing 450/600 and sometime being stock height and sometimes dropped at bit i live in the mountains tho so i cant always leave it slammed and need something i can change due to snow and dirt if their is no other ways ill just do billy sport was just wondering of any other cheaper shocks i could use for awhile so i dont have to buy the a full set of billy Dampeners and the GC kit in one go
                • Vivek
                  • 6167
                  Tokico Illuminas are $58 each right now (link is in that thread in off topic). Those may be fine although I can't really find much on them. For the rear, there's definitely cheaper options but it all depends on what you want. If you're fine with destroying the Boge dampers you can just use them for now and get billies later. I think it'd be a waste to get medium range shocks now, then bilsteins later--but it's also a waste to ruin your current dampers.
                  • kickinindian
                    • 2327
                    new plan idk why i didnt think of it before is just buy some cheapo dampers slap em on and send my existing Billys in to get rebuilt to GC spring rates......ill shut up now
