H&R race springs loose on install
  • purple haze
    • 51
    I have been installing my H&R race springs and blisten sports and found that when assembled, the shock is too long there is a massive gap between the hat and spring without compression pics below
    measured the length of the strut from the thread to base
  • E30_fiend
    • Apr 2006
    • 7348
    Everything is fine.
    The h&r race spring is much shorter than the stock spring. Install everything then lower the car slowly and make sure the upper perch is seated correctly on the spring. Once that's done lower it all the way down and go for a drive.
    Don't worry. You didn't do anything wrong. A lot of guys have asked this same question. It's just the length of the new spring playing tricks on you.
    Taylor
    • purple haze
      • 51
      but wont the spring bounce out of the perch again like on a bump or if i jack the car up? seems a bit scetchy
      • ClausE30
        • Sep 2011
        • 981
        I went through the same thing last weekend, swapped my stock springs for race springs and scratched my head when I noticed the same thing. like said above, just seat them correctly when lowering the car
        91 Alpinweiss2 318is OBD2 S52
        • purple haze
          • 51
          i didn't realise it was a thing, just did a search of the forum, thanks for the replies will stop freaking that i spent a load of cash on a setup that is fucked.
          will finish it tomorrow.
          • reelizmpro
            • 9558
            Haha if ur freaking out about race springs u should see how loose 2.5 in coilover springs fit. The rears fall out when the suspension is fully extended.
            88 M3 - LACHSSILBER
            89 M3 - ALPINEWEISS II
            • Jaxx_
              • Dec 2009
              • 1880
              Even if it doesn't seat correctly, it will after a few hard bumps. :)
              • Vivek
                attention whore/retard/bitch
                • 6167
                No. You should see how much space 5" length coilover springs have both front and rear at full droop.
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
