Better turn-in for E30
  • alexbaby88
    • 219
    For street use, what is the best way to get better sharper turn in for an E30?
    Thanks
    • 34847
    toe out helps, but too much and you'll be scared at high speeds. I also noticed a difference when I switched to offset control arm bushings (E30 M3 offset).
    • erik325i
      • Jan 2005
      • 3567
      I thought offset bushings hurt turn-in... The added caster is better for high speed stability, butnot good for sharp turn-in.
      I may be wrong though. I dunno
      -Erik
      • PeaveyBassist
        • Sep 2004
        • 3511
        -Erik
        Yep. Correct.
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
          • 34847
          could be, it was a long time ago that I switched. I just know they made the steering feel a lot better..
          • AdamF 88iS
            • 2051
            Offset bushings installed correctly hurt turn in but add high speed stability.
            Offset bushings installed backwards help turn in; yea, you can do that.
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • alexbaby88
              • 219
              what about camber plates at the front to add a bit of negative camber?
              • Charlie
                kid tested, administrator approved
                • 6686
                Camber.
                Best and easiest way to do it. You can achieve some extra negative without doing too much extra tire wear by going with the offset "crash" mounts for the strut top, or for less money just get a set of fixed -1 degree plates.
                -Charlie
                Swing wild, brake later, don't apologize.
                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                FYYFF
                • alexbaby88
                  • 219
                  Originally posted by Charlie
                  Camber.
                  -Charlie
                  Could someone point to a good online resource to purchase one of these camber plates for a decent price?
                  Thanks
                  • e30 gangsta
                    • 3877
                    Thanks
                    • asubimmer
                      • 6482
                      how about some Bav Auto springs ;)
                      • e30 gangsta
                        • 3877
                        garbage. And im honstely thinking about installing those cabs backwards. Anyone going against it?
                        • asubimmer
                          • 6482
                          they are actually really nice springs...have you ever had them? They are not harsh, handle well, and give a REALLY nice drop.
                          • e30 gangsta
                            • 3877
                            i have ie stage 3. Anyone go against installing the bushings backwards?
                            • ColdAccord
                              • 5926
                              they;re too soft and sag like a bitch.
                              Originally posted by blunt
