Right, but it has nothing to do with his alignment. Like I said, "Those numbers only exist to help the tech keep the steering wheel centered without having to remove it and center it afterwords."
Saying the toe could be "better" doesn't make sense, as his toe settings are perfectly within spec. The actual alignment is good, which is what this thread is about, not if the steering wheel is straight.
I know what you're saying, you like to center the wheel prior to the alignment, and then make the toe settings equal on each side so no wheel adjustment is necessary. I agree, that's the best way to do it. But it's not the issue at hand here... His total toe is correct, and it's not the cause of his noise issue, or any other issue for that matter, besides possibly the wheel not being straight.
