What causes negative front camber???
  • BROKINBIMMER
    • Nov 2012
    • 195
    1989 325iS
    200k
    Stock front suspension
    Extreme negative camber
    I did some searches and have been unable to figure this out. My struts are in good shape, they are not blown nor bent. Also, I just put on new front hub/bearing assemblies. Should I replace the lower control arms next? Would worn ball joints cause this??? Please help
  • Wh33lhop
    • 11705
    How extreme is extreme?
    A number of things could cause this. What strut mounts are you using? Offset? Centered? Are you sure the springs are OEM? Are you using the correct control arms? Control arm bushings?
    paint sucks
    • F34R
      sLaughter
      • 12376
      Incorrect over tire inflation? maybe the lollipops are bad on the control arm giving you more camber. Don't see how bad control arms could cause camber wear as they are a fixed part.
      I would replace them with Meyle arms if they are bad. Only get proper brand parts as they perform and LAST vs cheap Chinese aftermarket junk.
      Pictures would greatly help, Tires; both sides and a full shot with the wheel turned out. And maybe some of the bushings if you can do so.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • Mr. Tasty
        • Jul 2011
        • 3421
        bmw's generally have a bit of negative camber at stock. Are you used to driving a toyota yaris or something?
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • BROKINBIMMER
          • Nov 2012
          • 195
          Yea, the car was lowered when I first bought it. I recently installed used OE struts and OE springs. As far as I know, the lower control arms are the correct ones.
          • BROKINBIMMER
            • Nov 2012
            • 195
            How did you know? I daily my "stanced" yaris.
            • randomtask37
              • 3154
              lol new guy has a sense of humor
              98 M3/4/5
              • Vivek
                attention whore/retard/bitch
                • 6167
                Pics would help. Most things up front won't cause major camber changes when they wear out, so maybe something is bent or incorrectly installed?
                1992 Mauritiusblau Vert
                2011 Alpinweiss 335is coupe
                2002 540i/6 Black/Black
                2003 GSX-R 750 (RIP)
                • Wh33lhop
                  • 11705
                  You need to answer the questions asked of you if you want us to help. How extreme is extreme? Are we talking 5 degrees, 3 degrees or 1 degree?
                  paint sucks
                  • BROKINBIMMER
                    • Nov 2012
                    • 195
                    I'll post some pics tomorrow...I can't imagine what could be causing this
                    • BROKINBIMMER
                      • Nov 2012
                      • 195
                      If I had to guess, I would say more than 5 degrees
                      • Wh33lhop
                        • 11705
                        If it is really over 5 degrees and you are truly at stock ride height then something is seriously, seriously wrong.
                        paint sucks
                          Incorrect front camber when the car has stock springs will be from bent or wrong control arms or chassis damage.
                          • DRTSRFR
                            • May 2008
                            • 1836
                            Patiently waiting for pics...
                            Both sides?
                            Suspension tips here...
                            http://www.r3vlimited.com/board/album.php?albumid=757
                            • gtdragon980
                              • Jun 2008
                              • 1808
                              +1 The control arms are possibly the only thing that can cause neg. camber up front, other than lowering the car itself or structural damage to the strut tower. -5 degrees camber, and there is something seriously wrong with those parts.
                              FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                              Originally posted by scabzzzz
                              I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                              1989 325i - Project/weekend driver
                              2002 325i - DD
                              2005 Suzuki SV650 - Toy
