What causes negative front camber???
  • BROKINBIMMER
    • Nov 2012
    • 195
    #31
    Originally posted by ForcedFirebird
    So you spend a couple hundred to fix something that may not exist and would have cost you $50 on an alinement rack to verify?
    No. The car had worn LCABs, and I figured that 'may' have been the cause of the excessive negative camber.
    So why not replace something that I know the car needs that may fix another problem.
    • bmwguy325is
      • May 2011
      • 1263
      #32
      Originally posted by BROKINBIMMER
      No, I haven't. I was going to, but $$ is a little tight right now, and I would like to only align it once if possible. I'm thinking I'll need to replace more parts now to correct the suspension....
      ......No. The car had worn LCABs, and I figured that 'may' have been the cause of the excessive negative camber. So why not replace something that I know the car needs that may fix another problem.....
      So then how do you know what the camber really is?
      As mentioned quit throwing parts at the car and get it checked out.
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • Northern
        I like cupcakes & sh!tboxes
        • 5284
        #33
        Camber looks fine to me...
        Originally posted by priapism
        Originally posted by shameson
        • Earendil
          • 1662
          #34
          Cut him some slack. It sounds like he's only replaced items that he knew were worn. Why take it to an alignment shop when he has known worn suspension parts and is willing to fix those first?
          1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
          2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
          I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
          • ForcedFirebird
            • Feb 2007
            • 8300
            #35
            Control arms only need to be replaced when bent. Otherwise, replace the ball joints and CAB's.
            john@m20guru.com
            Links:
            • jeffnhiscars
              • Jun 2011
              • 6011
              #36
              Easy when you have a 15t press and the right jigs. I looked around and the labor plus the joints were more than the price of a new control arm.
              If you want some good cores I have a stack here with your name on it :-)
              Alice the Time Capsule
              • BROKINBIMMER
                • Nov 2012
                • 195
                #37
                Its much easier, and more cost effective to swap the whole arm as I'm sure you already know. And yes, I did replace the CAB bushings.
                My thoughts exactly.
                • BROKINBIMMER
                  • Nov 2012
                  • 195
                  #38
                  Ok, got it aligned. It has -3 degrees of camber. The car has zero frame damage, new struts, new stock springs, new control arms, bushings.
                  So what's next?
                  • Todd Black 88
                    • Oct 2007
                    • 3449
                    #39
                    -3 both sides in the front?
                    Post your allignment sheet.
                    Originally posted by codyep3
                    I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                    2001 silver/Blk 325 cabby. SOLD
                    2002 325xit Sil/blk. SOLD
                    2010 F650gs twin
                    • BROKINBIMMER
                      • Nov 2012
                      • 195
                      #40
                      OK, a lot of folks on here are going to disagree with what I'm considering doing...
                      What about elongating the strut mount holes to slightly move the top of the struts outboard? I know its unconventional, and probably not recommended, but I'm talking about 3/16" of an inch tops...Thoughts? Suggestions?
                      • BROKINBIMMER
                        • Nov 2012
                        • 195
                        #41
                        Yes, -3 on both sides. I will get the shop to email me a copy and post it here.
                        • Earendil
                          • 1662
                          #42
                          It adds real weaknesses, while adding no real benefits.
                          • BROKINBIMMER
                            • Nov 2012
                            • 195
                            #43
                            So running that much negative camber is not harmful?
                            • Earendil
                              • 1662
                              #44
                              Tire wear is the only negative (no pun intended). I mostly don't think that's the way to go about fixing it. All sporty cars have some negative camber. Drive it hard and the tire wear will even out, and do tire rotations :)
                              Or figure out what the REAL problem is. Anyone know what the stock numbers are? I'm thinking they're near 3 degrees. Maybe 1.5 or 2?
                              • ForcedFirebird
                                • Feb 2007
                                • 8300
                                #45
                                Originally posted by scottinAZ
                                alignment specs are as follows (as stated in my FMC book)
                                1987-91 E30:
                                wheelbase 101 3/16
                                front treadwidth 55 3/8
                                rear treadwidth 55 11/16
                                Camber (degrees)-.069+/-.050 Front
                                -2+/- .050 rear
                                Caster (degrees) 8.75+/- .050
                                Toe (inches/degrees)0.16+/-0.05 .031+/- 0.09 Front
                                0.19+/- 0.06 0.38+/- 0.13 Rear
                                Turning Angle outside 18.16 inside 20 Included angle 13.5
                                Notes,
                                Alignment should be carried out with the following load 150lb on each front seat, 150 on middle of rear seat, full tank of fuel 31lb in trunk.
                                suspension ride height should be as follows
                                Front 22 7/16 rear 20 1/16 tolerance of 3/8 inch
                                as Jlevie has stated, the only FACTORY adjustment is front toe, but this gives the full shooting match in case you have installed additional adjustment in the form of camber plates (front) or fully adjustable rear suspension (welded in kit)
                                Hope this helps
                                Search function is a good one.
                                john@m20guru.com
                                Links:
