I understand the geometry issues when lowering a car. It's a sacrifice many of us are willing to make, as there is no affordable/low maintenance solution to correct roll center that's suitable for a street car. The whole point of going to m3 end links in my example was not to increase roll bar stiffness, but to avoid the major binding problems.
My point is, when you lower it to a certain point, the control arm mounted swaybar link completely binds up. Not a little rubbing, but it 100% locks and doesn't travel any further. This is a very bad thing. Not a *not ideal* thing, but a *about to snap the end link in half* thing.
Like I said above, the links fully lock up and stop functioning when lowered to a certain point. The M3 links do create slight load when turning the wheel, but it's an equal and predictable amount in each direction, so you set it to zero preload when the car is flat for that same reason you would set zero preload on any other car.
If fitted to a factory height car, I'd agree. Lower it 2" or more, and they don't move at all, and lose all functionality.
Honestly, if you plan to lower your car a significant amount, going to M3 endlinks is the only option to prevent major binding with the links. Saying that you might as well not even bother dealing with the binding issues because the geometry isn't perfect, doesn't make sense to me.
