Sway Bar options
  • e30trooper
    • 11576
    Im running a vert front sway on poly bushings and 25 year old stock rear. My car sux :(
      • 34834
      Originally posted by jlevie
      So the shape of the sways makes a big difference.
      yes, the shape of the bar changes the length of the "spring" which determines it's stiffness.
      • oldmann
        • 265
        Originally posted by JRYE30
        I think I'm going this route after all that haha.
        IX 14.5mm
        Cabrio 22mm
        Is there a good bushing/endlink kit? for this size?
        New stock bushings and end links will work fine.
        You can find new heavy duty rubber bushings, I don't remember
        where I saw them.
        Source the parts for the car you took the bars off of for correct sizing.
          • 34834
          the endlinks are the same on all E30s. the bushings will be from an ix or M3.
          • AE86
            • 272
            Originally posted by oldmann
            If money is the problem, Use the rear bar from an IX (19mm) and the front bar from a cabrio (22mm)
            I run these on my 318i, Replace the stock bushings with something harder, and run new end links. Decent street setup.
            OOPS, IX bar= 14.5mm, Brainfart.
            Originally posted by nando
            the ix/m3 rear bar is 14.5mm, not 19mm. but, it'll still be a cheap upgrade over the 318is's 12.5mm bar.
            Cabrio front sway bar is 21mm
            WTB: Diamond Schwartz Hood
            • SkiFree
              • Jun 2011
              • 2766
              ......And the shape of the bar can dictate the length of the endlink. And subsequently the endlink length dictates the bars articulation (the shorter the endlinks, the less articulation the bar has, resulting in the bar going over-center much easier).
              ADAMS Autosport
