I just got through a suspension overhaul, I put in all new bushings (poly control arm and RTAB, all the rest OEM) the typical H&R / Bilstein sport combo, new tie rods, ball joints, control arms, wheel bearings, the whole shebang. I got an alignment immediately after. Since then, I have noticed the steering will pull to the direction I turned the wheel last. I.e. if I last made a left turn, the wheel will pull to the left, if I just made a right the wheel will pull to the right. It isn't a ridiculous amount of pull but it is enough to be pretty goddamn annoying on a 400 mile drive. I looked this up and found this thread on a similar issue but no conclusion was reached: http://www.r3vlimited.com/board/showthread.php?t=187743. The consensus seemed to be that the OP forgot to put the strut back together with the washer that goes between the upper spring perch and top mount and they are getting too close and binding.
I looked around and a few days after I had everything back together I noticed I had two rather large beefy washers laying on my bench, and I didn't recall putting any washers between the upper front spring perch and the mount, and there is one on the diagram. Would the absence of this washer cause this issue? I just wanted to get some opinions before I take the front struts apart again; while it isn't difficult to do I am at University and I have to borrow tools and space to do so.
Also, would I need to worry about any of the mounts being chewed up from this binding when I take it apart or could I just slap the washers on that are supposed to be there and be good to go? I have only put like 550 miles on the suspension so far and 90% of that was straight line highway driving.
Thanks, JB
Thanks, JB
