z3 rack swap nightmare
  • bastianshaw
    • Jan 2007
    • 2210
    How the fuck are you guys running the stock hoses? and dont say I flipped them, no way. it seems to me I can either have the HP hose from the pump or the feed line to the rack from the reservoir; do i need to go to a shop and have this bent?
    S3rious PITA if you swap racks plan on having no PS (still awesome, ive been running no ps for over a year)
  • Sagaris
    • Sep 2009
    • 2243
    I bent my stock line into some sort of hodge-podge oddity which worked, but was total crap aesthetically. I mean this thing was looping up and over the engine mount, the rubber portion was looped to make it shorter, it was total crap. I bought another stock line to try again, and strangely it fit just fine with no modifications needed.
    You may have seen this write-up, but maybe this pic will inspire some ideas.
    • Todd Black 88
      • Oct 2007
      • 3449
      I had to twist mine in a vice.
      Originally posted by codyep3
      I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
      2001 silver/Blk 325 cabby. SOLD
      2002 325xit Sil/blk. SOLD
      2010 F650gs twin
      • bastianshaw
        • Jan 2007
        • 2210
        even w bending the line I cant see how it would be easy to bolt these up w/o interfering w the steering knuckle or the low pressure line...can someone running PS w the rack snap a pic of the lines going into the rack?
        • LJ851
          • 7918
          I just tweaked the stock lines a little. It's hard to get a good pic.
          Lorin
          The M30 is God's engine.
          • defaultName
            • Jul 2010
            • 859
            I tried to install the line without bending it for a while, but then I gave up on power steering altogether.
            I'll probably try again at some point.
            Buy and sell your E30s and E30 parts on E30 Marketplace!
            • bastianshaw
              • Jan 2007
              • 2210
              did you feel likw murdering someone or lighting hella shit on fire?
              • bastianshaw
                • Jan 2007
                • 2210
                this is the e36 line so its not of much use to me but thank you, im trying to stay positive about the whole thing i guess it just cought me off guard I was nt expecting this much headache
                • Varinn
                  • 780
                  Does anyone know of someone who has had a custom high pressure hose built up by a hydraulic supplier? I haven't actually looked underneath at the routing and compared the racks but my swap is coming up soon and I'm thinking of having one built in advance
                  1990 332i, 4 door
                  2008 KTM 990 Superduke
                  2018 Golf R, 6spd manual (Pending delivery)
                  2017 Mazda CX-5 GT
                  2007 Z4M Coupe - Sold to very nice people
                  • defaultName
                    • Jul 2010
                    • 859
                    Yes, but I always feel that way! But seriously I figured it would be a pain to fit the line before I started so I bought a PS delete from Condor Speed Shop just in case.
                    I found this from Zionsville Autosport...
                    It says "This steering hose is a new factory part which has been modified to connect the quick ratio steering rack to the e30 steering pump." so I would ask if "modified" just means bent or what.
                    • Boostesi
                      • May 2011
                      • 220
                      i used stock e36 lines with only minor hand bending, but i have an m50 in my car, and its a late model... these things may make a difference
                      sigpicFellow e30 enthusiast
                      Dont waste your time hating, aint nobody got time fo dat
                      1986 bronzit 325es- SOLD
                      1987 delphin 325i- parts car
                      1990 scwarz 325is- m50 drift slut
                      CHECK OUT THE BUILD!
                      http://www.r3vlimited.com/board/showthread.php?t=229234
                      • jeffnhiscars
                        • Jun 2011
                        • 6010
                        Im not sure how much the Z3 rack varies from an e36 rack but I've done 2 swaps. The 1st was in to the M10 which had the angles flare connector instead of banjos. That was easy. On the M20 swap I recall using the pump as a vice by bolting the e30 hose to it and prying against the metal pipe on the hose. I was just trying to take some stress off the re-routed hose so it didnt take much to get the angles right.
                        That probably doesnt help much :-/
                        Note: I just got my reman e36 rack to swap in to the barn find and I'll probably be punished on that for posting this.
                        Alice the Time Capsule
                        • Varinn
                          • 780
                          Cool thanks for that link, another question. Is the standard e36 rack different in dimension than the z3? I see many people claiming to just do a direct reverse of the hoses with no bending while others are doing tons of bizarro twists to make it fit
                          1990 332i, 4 door
                          2017 Mazda CX-5 GT
                          • bastianshaw
                            • Jan 2007
                            • 2210
                            im highly skeptical of this, i tried reversing the hoses and it no worky
