Do I need to shorten my bilstein sports if I lower the car
  • AbsorbantNut
    Non faccio funzionare questa merda
    • Jun 2010
    • 2491
    Hey guys, I also ordered a pair of shorter front coil springs. I was wondering if I'm going to need to shorten my Bilstein Sports as well when I ship them in to get rebuilt. Or will the sports be able to function fine without being shortened? I'd rather not spend a ton of money if I don't have to:p Thanks!
    -Jay
    '73 2002 m20 turbo [sold] '87 rat rod 325is [couch modded] '91 vert [daily] '88 325is [spec build v1] '84 325 [spec build v2] '99 323i vert [sold]
  • AndrewBird
    The Mad Scientist
    • 11897
    Sports are already shorter then stock, so no need to shorten. Unless You are talking about stock iS shocks, in which case those are normal length.
    • mbonanni
      • Sep 2011
      • 6236
      Sports are stock length I am pretty sure, the ix bilstein hd fronts are shorter, right?
      You will not need to shorten them unless you plan to section your housings.
      • AndrewBird
        The Mad Scientist
        • 11897
        HD's are stock length, sports are shorter. Both are valved the same.
        • LJ851
          • 7918
          HDs and Sports have full height bodies and fit in stock E30 strut housings. The Sport damper has a shorter rod to position the piston in a more favorable place in the stroke for lowered cars.
          IX Bilsteins have a shorter body and would need the strut housing shortened to use on a standard E30 BUT you would gain the amount shortened in upward suspension travel which is a good thing on a lowered car.
          Lorin
          The M30 is God's engine.
          • mbonanni
            • Sep 2011
            • 6236
            I meant ix Bilstein HD struts are shorter, anywho.
            I still think you are wrong.. The bilstein sports and the Bilstein HD's are the exact same length, and they also valved the same.
            What is different is the internal lengths, or the pistons and the bump stops to be more exact. The HD's have longer bump stops, so when you lower a car on HD's you end up sitting on the bump stops the whole time, rather than Bilstein sports which have shorter bump stops.
            If the bilstein sports were shorter then you would have to shorten your housings, which you don't.
            Either way, you do NOT have to shorten anything.
            EDIT: He beat me to it. I took too long to type my response.
            • AbsorbantNut
              • Jun 2010
              • 2491
              Well thank you all for the help, that was very informative & looks like I'm back on the right track again!
              • jeffnhiscars
                • Jun 2011
                • 6010
                It sounds like you are saying that the ONLY difference between the HD and Sport is the length of the bump stop ?
                Since they are easy to cut down this makes no sense.
                Alice the Time Capsule
                • mbonanni
                  • Sep 2011
                  • 6236
                  No the internal piston length or rod, I don't remember fully right now, is different as well. I just chose to talk about bump stops for whatever reason I do not know. lol
                  Give bilstein a call, ask for Juan, and he can explain everything and make sense out of it.
                  • AndrewBird
                    The Mad Scientist
                    • 11897
                    I was speaking about travel, not overall outside dimensions.
                    • JGood
                      • Jan 2004
                      • 7959
                      From what I've read from Ground Control, Sports and HD's are the same length compressed, and use the same valving, but the HD's allow for one inch more droop.
                      e30 restoration and V8 swap
                      24 Hours of Lemons e30 build
