iC suspension overhaul
  • bowtie2bimmer
    • 830
    In the midst of gathering parts for a suspension overhaul on my 87 iC. So far
    Control arms w/ off set ca bushings
    new tie rods
    motor mount
    Tranny mounts
    Powerflex poly subframe, diff, & trailing arm bushings
    inner/out cv axle boots
    Front and rear sway bar end links
    Front and rear upper shock mounts
    Front upper and lower spring pads
    rear upper and lower spring pads
    H&R touring cup kit
    Anything else I am missing?
    1987 BMW 325ic - Emma
  • 325ix
    • Aug 2009
    • 7783
    Sway bar bushings is the only thing I can see, maybe do the guibo while your in there replacing things of that nature.
    • bowtie2bimmer
      • 830
      rubber fine or poly? just looking for a fun DD
      • Roysneon
        • 4505
        Good quality rubber parts are fine, but poly lasts longer.
        Originally posted by mbonanni
        I am a pursit now.
        • jeffnhiscars
          • Jun 2011
          • 6011
          I'd throw in an e36 rack and how do you like the cup kit ?
          Alice the Time Capsule
          • bowtie2bimmer
            • 830
            not installed... looking to do a 3 day blitz on the car once its all collected
            • CrusherCurtis
              • 2532
              List looks good. PM me or post who much you spent on every thing once ordered. I did every thing on my front end top to bottom last spring.
              • jeffnhiscars
                • Jun 2011
                • 6011
                I'd love to see pics when you are done. I like the fact that the cup kit only drops the rear by 3\4in since my sits low enough now and most lowering kits drop it an inch+.
                • lowsodium
                  • Dec 2012
                  • 289
                  Im about a month away from ordering every suspension part needed for a rebuild. My suspension is utterly shot. Appreciate the list, and any additions we should need.
                  Where are you ordering most of it from?
                  Haven't you ever seen Russian Nesting Dolls? They work like that.
                  1987 325e / 2008 135i
                  • NV325i
                    • May 2012
                    • 236
                    Anyone else using the touring cup kit and how does it compare to the eibach pro kit/bilstein sport setup.
                    Current: '92 325i Vert
                    Past: '84 Euro 320i -Had to leave in Italy
                    • bowtie2bimmer
                      • 830
                      Pelican Parts... And before anyone gets on their high horse how other companies are better, over the part year i have done several orders and they have been great with customer service and pricing.
                      Sent from my DROID RAZR using Tapatalk 2
                      • F34R
                        sLaughter
                        • 12376
                        Is this a build or a suspension list request?
                        Instagram: @BWeissLeather
                        Current cars:
                        ~ '87 325 M30B35 swap
                        ~ '87 535
                        ~ 01 540 Msport 6spd
                        ~ '06 X5 4.8is
                        • bowtie2bimmer
                          • 830
                          That's what i have going so far... some i have, some still need to be ordered. Just seeing if there is anything else to add while I've got it apart
                          • roguetoaster
                            Biggus Tippus
                            • 7830
                            Have you tried pricing vs. AutohausAZ? When I did my refresh I came out a few bucks ahead there versus Pelican.
                            • andrewm
                              • 456
                              Rear strut mounts arent on the list. And the spring pads aren't really all that needed, at least not for the non verts. I took mine out to lower the car an extra 10mm in the rear
                              1987 Delphin 325e Sedan - Natalie
                              1990 325i 24v
                              1997 Chevrolet K1500 Crew Cab 4x4 - The Centurion
