Penetrating lubricant, heat it with mapp gas torches (about $50 from home depit), stick a pry bar between the spindle and the strut tube, and put a pipe wrench on the collar, and stand on the handle.
It's what happens when the heat causes a pressure buildup, and the seal fails, spraying hot oil all over you. Or worse, a violent rupture of the strut housing.
Will it happen? Probably not in a violent way, but it is entirely possible and reason enough to leave the "easy" button on the shelf this time.
No E30 Club
Penetrating oil and the 36" pipe wrench did the trick!
Thanks guys!
Now to tackle the inner ball joint on the right hand side.
Have fun with that.
Haven't had to replace one yet on an e30, but in my experience a good adjustable wrench and cheater bar will do the trick. That is, if you have the clearance.
No E30 Club
We ended up cutting it on the left, we got enough out to get a die grinder in there and went nuts. Finished with an air chisel.
I don't want to pull the exhaust so options are limited for the right.
- Josh
1990 325is
Need a shift boot? Looking to buy shift boot frames, PM if you have one to sell
Living in the rust belt sucks. We had to replace 2 housings on a 318is that were just too far gone. Youre lucky you didnt just destroy whats left of the threads
WTF? What happened to the God's Country of legend?
