Gland nuts rusted solid.
  • flyboyx
    • 8371
    well, for future reference next time, heat the hell out of the nut and upper area with a torch. i have done it several times and had no issues ever. most of the time, you are taking them apart because the struts are blown anyway. if the aren't, the seals on the shock/strut are plastic or rubber so they will melt before anything will explode.
    Gigitty Gigitty!!!!
    • Cletonius
      • 2809
      Originally posted by agile30
      Use a 7/8 crow foot and extensions. Lots of them.
      Yeah, I think I'm gonna have to pick one up. Sucks when it gets loose enough where it starts spinning. That's why we had to cut the left side one. The piece is still in the cross member. :(
      - Josh
      1990 325is
      Need a shift boot?
      Looking to buy shift boot frames, PM if you have one to sell
      Here's what happens when you let the internet pick your license plate
      • TimKninja
        • 2131
        22mm long ratcheting wrench for that inner ball joint.
        Mine where rusted worse then that. Lots of PB, heat. And a huge pipe wrench freed them up .
        1985 325e M50TU(Sold)
        1991 318is Slicktop (Sold)
        1990 325is Brilliantrot S50/5 Lug Swapped.
        1992 525i Manual shitbox Winter Beater
        • pandaboo911
          • 2070
          Dafuq? You cut it??
          When it spins you put a jack under it and put the weight of the car on it.
          • Cletonius
            • 2809
            Originally posted by pandaboo911
            Dafuq? You cut it??
            We tried that. Even lifting the car off the stands by the one joint wouldn't stop it from spinning. We took the nut most of the way off and then it stopped. We cut it off as close to the arm as we'll could so we'd have something to grab with vise grips.
            - Josh
            1990 325is
            Need a shift boot?
            • F34R
              sLaughter
              • 12385
              As stated above, large pipe wrench and a 3' section of pipe to extend the handle. Put the housing in a vice and apply force. I have personally used heat before, never blew up on me.
              Instagram: @BWeissLeather
              Current cars:
              ~ '87 325 M30B35 swap
              ~ '87 535
              ~ 01 540 Msport 6spd
              ~ '06 X5 4.8is
              • Exodus_2pt0
                • 5943
                Like I said, your probably going to be OK using heat. Doesn't mean it doesn't pose a risk. Honestly, there isn't any need to use heat though.
                No E30 Club
                • ravenlord89
                  • May 2012
                  • 111
                  I had replacement bilsteins. They have a nice threaded collar so there isnt a need to use the stock collar. So all I did was weld a piece of angle iron to the stock collar and out it came. Not really any use if you don't have replacement collars.
                  As for that balljoint, just remove the exhaust, and put the impact gun with extension onto the nut and she comes right off... Or use a stubby 22mm wrench. I prefer to remove the exhaust myself.
                  1990 BMW 325is 5spd Black
                  2005 Subaru Impreza 5spd
                  2015 Yamaha FZ-07
                  • Cletonius
                    • 2809
                    The front half of the exhaust looks original to the car, I'm a little scared to remove it. Rusty+++ and I'm not prepared to replace it at this time. I've got the O2 out and that gave me a some extra room. Gonna try with a cut wrench today and see how it goes.
                    I'm hoping I can get the rear subframe out today as well.
                    - Josh
                    1990 325is
                    Need a shift boot?
