Custom E30 suspension, this looks awesome!!!
  • BMWerke
    • 893
    So I stumbled upon this listing on ebay. basically this guy modifies the e30 knuckle so that you "Clamp" on a strut like how alot of BMWs and other cars are instead of dropping the strut into the tube and securing it with the collar nut on top. So with this you could literally run any length strut from any car just as long as it is the right diameter. this would solve ALOT of problem for us guys looking for a good and reasonably priced front strut. does it look sketchy or legit????
    http://www.ebay.com/itm/BMW-E30-Susp...c91f7a&vxp=mtr
    '90 325is DD, 5 spd swap-H&R springs-Euro Headlight Fully Built OBD1 M54b30. Ox Blood interior, 3.46 LSD with Z3M Diff Cover. Custom shifter, every bushing replaced.
    '86 325e- Donor car for swap/parts car
    '00 323i- BBS 197s Totalted
    '89 740 turbo Volvo- Donated
  • noE30
    • Jun 2008
    • 2260
    Looks like an interesting idea but don't most newer bmw's bolt to the spindle like these e36 coilovers..
    Flickr
    @michael.colby on Instagram
    "All he needed was a wheel in his hand and four on the road"
    • ChaseN
      • 709
      I know at least the e39 works like the suspension shown in the OP.
      1991 318iS
      1992 911
      2006 330i 6-Spd ZSP people hauler
      Gone:
      1989 M3 S50B32, 6-Spd
      1990 325ix 5-Spd
      • PaladinReed
        • 1524
        Whoa. That's a biggie for us e30 guys. And am I reading that right? Swappable spindles?
        Late model granitesilber 325i convertible FS:
        http://www.r3vlimited.com/board/showthread.php?t=293701
        • nrubenstein
          • 3148
          No.
          And this is a completely silly idea.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • noE30
            • Jun 2008
            • 2260
            Looks like its geared towards e46 suspension, which is in fact not the same style as an e36. My mistake.
            Flickr
            • 88SuperETABD
              • Apr 2009
              • 911
              This would be a bad way to lower your car...since the tie rod/control arm mounting points go up along with the spindle. It doesn't correct for geometry. The best way to lower the car would probably be the way ground control does it by chopping and rewelding.
              (SOLD) 1988 327i Build Thread: http://www.r3vlimited.com/board/showthread.php?t=155086
              1970 Gruppe 2 2902 M20 Turbo Build: http://www.r3vlimited.com/board/showthread.php?t=373891
              • BMWerke
                • 893
                [QUOTE=noE30;3670889]Looks like an interesting idea but don't most newer bmw's bolt to the spindle like these e36 coilovers..[QUOTE]
                Yea I meant like e46 and e39 "newer" lol
                yea the guy has another listing for the adapter kit to run 5 lug spindles.
                • Raxe
                  • 5346
                  What's so bad about the pnp Koni yellows and Bilsteins? An equivalent E46 strut isn't any cheaper..
                  • F34R
                    sLaughter
                    • 12376
                    549.00 then you have to buy e46 inserts...explain how that is cheaper than proper Koni SA with shortened housings?
                    They are 400.00 for the pair shipped to my door. You can convert to plain old e36 front and ti/z3 rear hubs for less than 400. Ebay guy fails hard.
                    Instagram: @BWeissLeather
                    Current cars:
                    ~ '87 325 M30B35 swap
                    ~ '87 535
                    ~ 01 540 Msport 6spd
                    ~ '06 X5 4.8is
                    • BMWerke
                      • 893
                      well you would be paying $400 for konis up front and you have to buy rear shocks plus another $400 for ground control sleeves and springs then you have to do the shortening of the housings and welding the perches and all that good stuff. with this you would technically be able to go and buy e46 coilovers which have the threads integrated to the outside of the shock for the adjuster. and e46 coil overs go for $400 all day for everything including shocks. so it would actually be a little cheaper and with no fabrication up front.
                        • 34844
                        Looks like a neat idea. But, it doesn't cost that much to modify E30 housings. I guess it opens up some more opportunities.
                        $400 E46 coilovers are going to be typical Ebay garbage. You can get $400 Chinese coilovers for the E30 already if all you want is looks.
                        • BMWerke
                          • 893
                          I know a million e36 and e46 guys who have been on racelands for years with no problems what so ever, they are $400 and with a 2 year warranty on the shocks. And they dont hassle you if you trouble with the shock, they send you new ones and it comes with a prepaid return box. you cant beat that.
                          And yes WE NEED OPTIONS, I just blew my 2nd set of shocks and im only on H&R sports.
                          • gtdragon980
                            • Jun 2008
                            • 1808
                            Dude, racelands ride like absolute trash. It feels like a civic with stiff lowering springs on blown shocks. Bouncy and harsh. Now there are some decent $500 coilovers that have some pretty good reviews, which I plan to get for mine if I don't sell it.
                            FREE BITCOINS!! http://qoinpro.com/71690d1639966bfbf223bf16538cec21
                            Originally posted by scabzzzz
                            I stand up, pull my dick out, and asked my gf to give me some noggin... Well, she starts laughing at me and I freaked out and ran off and locked myself in a bedroom.
                            1989 325i - Project/weekend driver
                            2002 325i - DD
                            2005 Suzuki SV650 - Toy
                            • LJ851
                              • 7919
                              And yes WE NEED OPTIONS, I just blew my 2nd set of shocks because i'm on H&R sports which are 13% stiffer than a ball point pen spring.
                              Ftfy.
                              Lorin
                              The M30 is God's engine.
