Aftermarket tie rods
  • steveo777
    • Mar 2013
    • 9
    I dont know if anyone else has had this problem but this past weekend I swapped out my steering rack and ran into many obstacles along the way.
    The biggest one however was the "OEM" replacement tie rods by uroparts.At $17 per tie rod assembly, how could I resist what shouldve been a great cheap replacement.
    With those tie rods in, the bottom of the outer rod where the ball joint is was scoring into the inside of the wheel. I am on stock 14" bottle caps and you will not have this problem if you have any larger wheels. That hardly makes it an OEM replacement if it wont fit with stock wheels.
    Buyer beware.
  • ///M42 sport
    • 3952
    tie rods tighten all the way?
    I just did the same swap this weekend. Got the lemford w/o issues.
    • nickmcc92
      • Dec 2012
      • 442
      I bought lemforders w/o issues too
      • mr ilia
        • May 2011
        • 582
        What brand were those tie rods?
        I have Kralyn's on the way from Pelican...but I also have 15in rims.
        • steveo777
          • Mar 2013
          • 9
          i ordered uroparts tie rods, i have also read that people have had problems with meyle
          the key point is that they wont work on STOCK 14in bottle caps
          how can that seriously be considered an OEM replacement?
          • F34R
            sLaughter
            • 12376
            Been using Meyle for years, and racing on them for over 3 years. No issues.
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • steveo777
              • Mar 2013
              • 9
              Are you using the whole tie rod assembly or just the outer rods?
              • F34R
                sLaughter
                • 12376
                Whole
                Current cars:
                ~ '87 535
                ~ '06 X5 4.8is
                  • 37832
                  Meyle tierods are good quality and absolutely fit.
                  I have seen the same issue the OP is having with a cheap replacement ball joint. It's been a while so can't remember if it was URO or Karlyn. I'd stay away from both regardless.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • jeffnhiscars
                    • Jun 2011
                    • 6011
                    As has been said it's quite possible you got poorly made parts. Assuming nothing is bent and that you installed both sides of the rack in the correct subframe mounting holes, I'm wondering if you somehow wound up with e36 tierods which are side specific.
                    Alice the Time Capsule
                    • steveo777
                      • Mar 2013
                      • 9
                      interesting, i guess thats possible however looking in comparison to genuine oem tie rod ends there is no taper downward where the balljoint is and i believe it is millimeters longer. i don't believe they were side specific. so what aftermarket brands undoubtedly work with bottlecaps?
                      • ///digitalme
                        • Dec 2009
                        • 2088
                        Anything uro has poor fitment!!! Stay away from their products. Had the same thing happened on my old e30.
                        • Sea Aych
                          • Apr 2013
                          • 765
                          They don't? how about 14" weaves?
                          I'm looking for whole "tie rod assemblies" (outer) and just want to know if i'm just as well off using FEBI or MEYLE as opposed to the Lemforder OEM ones..
                          thanks!
                          1988 Atlantisblau Euro/Japanese 325i Cabriolet
                          1989 Schwartz 325i - now M50 powered! - now very dead
                          1998 Toyota 4Runner Limited
                          My 17,000km Big NA National Parks trip!
                          • SkiFree
                            • Jun 2011
                            • 2766
                            Either of those will work fine.
                            ADAMS Autosport
