Spring pad question.
  • mulletman
    • May 2012
    • 801
    Originally posted by carfantiti
    weird why you buy race springs with those concerns should bought sports?
    Because the softer sport springs will compress more than the race springs under the same load.... yielding more concerns with bottoming out.
    Also, the drop difference between sport and race is minimal.
    • pandaboo911
      • 2070
      If you have race springs might as well ditch the pads, and consider running a skid plate. Shitty roads + low e30 = broken oil pan. Ask me how I know
      • GT BMW E30
        • Nov 2008
        • 2491
        H&R Sports with drop hats in the front. If you go race on bad streets you will bottom out crack oil pan and possibly effffff the rear arch up too.
        • Aviator
          • 616
          Is there upper and lower spring pads? Gonna tear into this next week, just trying to have everything for the swap ahead of time.
          84 325e Burgundrot S52 M Tech 1.
          http://www.r3vlimited.com/board/showthread.php?t=250109
          • carfantiti
            • 790
            just went nice little ride with my race spring and no pads .I hear no noises .
            I might in future put the smallest pad possible only for piece mind so it is not metal to metal ,chance rust or ware.
            • Cletonius
              • 2809
              Yes, both front and rear have upper/lower pads
              - Josh
              1990 325is
              Need a shift boot?
              Looking to buy shift boot frames, PM if you have one to sell
              Here's what happens when you let the internet pick your license plate
              • AndrewBird
                The Mad Scientist
                • 11897
                FYI, H&R race springs are pretty much identical to IE stage 3's. Most would agree as well that the front will look higher then the rear. Some people cut 1 coil off the springs in the front to help with this. When installed, that one coil is fully compressed, so cutting it off will not affect anything but height.
