Any DIY alignment for E30
  • jaydeep
    • Jun 2011
    • 208
    Is there any DIY alignment for stock E30? What should be measurmant for toe?
    I am going to follow this link
    sigpicGLETSCHERBLAU METALLIC with leather INDIGO LEDER interior and blue top.
  • flyboyx
    • 8371
    run a string from the back tire up to the front on both sides. i set my tow at 1/8 to 3/16". tis good for a while, but you really need to get it done professionally.
    Gigitty Gigitty!!!!
    • nickmcc92
      • Dec 2012
      • 442
      I simply put the steering wheel straight. Lay down beside my car and line up the tires with eyes. Usually works well for me.
      • evandael
        • Oct 2009
        • 2881
        depends on driving conditions but 1/16" total toe in for stability or 1/16" total toe out for quick response. i feel like a laser level or the string method would work decently well.
        that's really all you can adjust until you start modifying suspension components.
        • Dj Buttchug
          • Jun 2010
          • 7677
          its so much easier to just swing into a shop with a laser rack and pay the 50 bucks to have it done properly. most of the time it comes with a warranty too
          Turbo M42 Build Thread :Here
          Ig:ryno_pzk
          I like the tuna here.
          Originally posted by lambo
          • george graves
            • 19997
            $50? Closer to $80-100 in my experience. Would love to pay $50!
            I looked into doing it myself. But it was going to be way, way to much work to even get close to any kinda of 1/32" tolerance. If you mess up, you won't really know until you see bad wear on your tires - so there's that too.
            Originally posted by Matt-B
            • Dj Buttchug
              • Jun 2010
              • 7677
              wow thats alot. The Big O tires does them for 55 after tax here in cedar shitty utah...
              Ig:ryno_pzk
              • george graves
                • 19997
                Oh - it might because I have an adjustable rear subframe. So I always get the 4 wheel alignment. Forgot about that part.
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Yeah, front wheel, single point alignment here is $50 as well.
                  And I agree, spend the money and get it done professionally. Tape measure works ok to get it to the shop, but not much else. It's not like you have to have it done often anyway.
                  • AsharC
                    • Jun 2011
                    • 1508
                    If you know someone that works at a tire shop, you can usually get a hook up. I get my alignments done for $40.
                    BUY MY WHEELS! BBS E50s!!
                    http://www.r3vlimited.com/board/showthread.php?t=275407
                    Originally posted by Lurker27
                    Any man will tell you being blown is better than being stroked.
                    • gath
                      • 577
                      I remember reading somewhere here about someone developing a DIY alignment tool but I can't find the thread.
                      • slammin.e28
                        שמע ישראל
                        • 12054
                        Hunter developed a great alignment machine. Trying to duplicate what they do with string and lasers, you're going to have a bad time.
                        • redsubdivisions
                          • Feb 2011
                          • 1762
                          +1. Just go get it aligned and save yourself a hassle.
                          1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
                          2012 Passat TDI - DD Duty
                          2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
                          • F34R
                            sLaughter
                            • 12376
                            I do this, then take it to a shop to get in spec. Eyeing it does not get it right for daily. Cost is about 60.00 around me for a 3d scan with the wheel mounted alignment guides.
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
                            • slammin.e28
                              שמע ישראל
                              • 12054
                              I'll mark and measure my old parts when I install new (tie-rids, etc), then get it aligned when I go to work. Tires and alignments are two things I'll pay one of the techs at work to do. Fuck DIYing that shit. Plus too it's like $35 for me. ^_^
