DIY sway bar end links?
  • e30experiment
    • May 2013
    • 132
    someone must have done this before?
  • oliver.r
    • Mar 2012
    • 3839
    why diy? theyre super cheap!
    • noid
      • 1536
      DIY install or DIY end links?
      Install is simple. For the front: undo one 13mm nut on the control arm and undo bolt/nut on the sway bar end.
      Rear: undo one 13mm nut on the trailing arm, pull the sway bar link off, lube up the shaft with astroglide and push the new sway bar link on, then reconnect to rear trailing arm.
      Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
      Your resource to tools and tips: www.rtstools.com
      • e30experiment
        • May 2013
        • 132
        link?
        I have seen a set of 4 ends for 19.99 on a website, that would do either rear or front.
        • mr ilia
          • May 2011
          • 582
          Too simple for diy.
          • e30experiment
            • May 2013
            • 132
            pretty much from googling, its just a male and female i believe right and left threaded ends together.
            • JGood
              • Jan 2004
              • 7959
              Yep, male spherical rod ends (L & R threads), and female threaded rod. Rod length will depend on front or rear application, as well as control arm or strut mount for the front.
              e30 restoration and V8 swap
              24 Hours of Lemons e30 build
